Clutch Basket Cover Guard?
Greetings!
Brilliant ride at Hungry Valley (Gorman, CA) ride cut short this weekend due to a dumb dumb dumb zero speed drop (yes, all rider error all the time haha), right on to a perfectly shaped rock to punch a pie slice shaped piece off the clutch cover. Out comes oil, weekend ends on day 1, dammmmmmmmit. I have seen the glue on clutch cover guard, but was really hoping to find an actual case saver, but apparently my google search skills are weak. Anyone know of anyone making something like that?
Thanks.
Timo
ps. Just got back into dirtbikes, last one I had was maybe a 95'ish XR600R, and I love this bike, clutch cover notwithstanding!
Thanks.
Timo
Re: Clutch Basket Cover Guard?
you want a new or used original cover?
or the one with the glue?
e-bay is all you need
Timo,
there IS something you can use, to either prevent or save your current clutch cover:
http://www.motorcycleproducts.org/Engine_Guards/XR650Rguards/XR650R.htm
If you fix - as best as it goes - your current cover, and next glue this thing on & it will look (and be) fine.
if you look close enough you can see the glued on case saver
Fiep,
you bought that because you ruined the std cover or for just in case?
I'm actually contemplating for the latter, that's why - lotsa rock here.
it was on the bike when I bought
just thought the picture would help
» Sounds like clutch basket?
» Clutch Cover Any Takers ?
» Clutch basket removal without fancy tool
» Anyone running this clutch cover:
» Clutch Cover
» Clutch Cover
