Valve clearance on the pig
Post  lolo on Mon Mar 14, 2011 8:55 am
Been checking out on the details of valve clearance.. its not the same as XR650L thou. How do i know whether its TDC? and if i'm doing the right thing. Any direction or site for me to guide, doesn't want to do the wrong thing by acting smart. better to ask then sorry. Crying or Very sad
Thank you very nice..
lolo
lolo
Edited 14 March 2011 to correct procedure!
Post  BuRP on Mon Mar 14, 2011 11:32 am
Let's see if I remember the Manual (never done it yet myself):
Best is to remove the LH side-cover.
Remove the spark-plug also!!!!
Of course remove the tappet covers too.
Then turn the crankshaft counterclockwise, and only counterclockwise, at least 2 or 3 full turns, until the 'T' lines up with a marker.
Check if all four valves have some play / are loose: if not turn another full turn (counterclockwise!!) to T.
If all four tappets are loose adjust the valves.
If this doesn't work then a) I'm explaining it wrong b) the valves are too tight c) you're working on a 2-stroke d) ask again Smile
Last edited by BuRP on Mon Mar 14, 2011 7:44 pm; edited 1 time in total (Reason for editing : I was wrong indeed - but now it is correct, as per H's Service Manual)
Re: Valve clearance on the pig
Post  lolo on Mon Mar 14, 2011 1:27 pm
hahaha... ok i will try and den ask again.... thats funny
den if the bike kapooot.. HoW..?
Any input from the other pig owners..
lolo
Post  lolo on Mon Mar 14, 2011 2:26 pm
found the valve clearance section already.. i post on the wrong site.. Embarassed
lolo
Post  BuRP on Mon Mar 14, 2011 7:46 pm
Lolo,
I've edited my above to the correct procedure.
