DC rectifier options
Post  Farmer on Thu Dec 29, 2011 8:02 pm
hey guys. Quick question.
I just picked up a 200w Ricky Stator and I'm about to wire up a dual sport kit. From what I understand, I should be able to run the headlight and taillight with the stock regulator on AC and the signal lights, horn ect on DC.
What is the preferred DC rectifier?
Also, because I don't want to use a battery do I have to use a capacitor? Which one?
I've got to get this stuff sorted before spring.
Thanks a bunch
Farmer
Farmer
XR650R Year : 2006
Re: DC rectifier options
Post  Mauser on Thu Dec 29, 2011 9:42 pm
I would pickup a stock rectifier from any street legal 250/400 R always loads on ebay, I am sure they woudl handle your 200 watts without any problems.
You could use AC for everything but I struggled to get a decent sound from an AC horn and there are not many about, I swapped out my US wiring loom for a UK model with a good friend and run all standard electrics now, added blinkers, horn and larger headlight with switchgear and brake switches.
Makes the bike more comlicated but safer to ride on the road.
capacitor?
Post  Farmer on Thu Dec 29, 2011 11:47 pm
What about a capacitor? do I need one of these if i dont run a battery?
Farmer
Farmer
XR650R Year : 2006
Post  Mauser on Fri Dec 30, 2011 9:36 am
Farmer wrote:What about a capacitor? do I need one of these if i dont run a battery?
Depends if your stopping with AC or going for both and what you intend to run on the bike, "if" you get a stock wiring loom it will come with rectifier / regulator behind the headlight next to this is a capacitor Smile.
I didn't have any problems swapping out the loom, stator and other parts as mentioned above.
