I need two 8 mm inner diameter 10 x .40 mm shims
Post  AURORA on Sun Jan 08, 2012 11:37 pm
I need two 8 mm inner diameter 10 x .40 mm shims and two 21 x .15 mm shims.
Thx
Re: I need two 8 mm inner diameter 10 x .40 mm shims
Post  BuRP on Mon Jan 09, 2012 4:12 pm
If you say 'what for' that would have been better - but measure the thickness of the thick-type aluminium foil, used here to grill fish in/on? Cuts like cake hence easy to make. Ah, no, not suited for any torque-transferring, just in case, but as 'spacer' they'll do fine.
Post  AURORA on Tue Jan 10, 2012 4:26 am
I moving up to .47 and 11.0 springs. Thus I need to add some shims to the rebound and compression stacks.
