Baja Designs 250W Stator install
Baja Designs 250W Stator install Empty Baja Designs 250W Stator install
Post  Guest Sun Apr 01, 2012 6:15 pm
Part 1 - Removal of stock stator
Baja Designs 250W Stator install SDC10015
Getting setup: OK, this may be a little basic for anybody who's worked on bikes before but I'll keep it there for anyone who has not's sake. A dirtbike stand is a great thing keeping the bike level and steady while work is performed. If you don't have one, a cement cinder block or a upside down 5 gallon bucket works great too. Smile
Baja Designs 250W Stator install SDC10017
Shift Lever: I have always kicked myself for taking the lever off without marking it first (Sharpie pen) and fighting with it later to get it back where I'm used to it being at. Seems like a "Duh" thing but if you're in a hurry and not thinking ahead it makes more work later....
Baja Designs 250W Stator install SDC10018
Seat removal: After the seat is removed make note of how everything is routed. Take a picture or use mine. Smile It'll be a while before you get the stator back to re-install, don't count on remembering how it was routed. At this point I removed the zip tie holding the wires to the subframe.
Baja Designs 250W Stator install SDC10019
Wire Routing: More referance pictures...
Baja Designs 250W Stator install SDC10021
Wire Routing: With the gas tank removed. Note that the zip tie/cable tie has already been removed from the subframe near the upper bolt in this picture.
Baja Designs 250W Stator install SDC10024
Cover: Only 4 bolts holding this on. Between the gasket, locating studs and magnets, there's a bit of resistance getting the cover off. There are are little tabs or ears near each of the bolts to pry against GENTLY with a small pry bar or allen wrench to pull it away from the engine. Try to remove it evenly. If you are patient and carefull it can be removed without damaging the gasket, cover or sealing surface of the engine case.
Baja Designs 250W Stator install SDC10025
Stator: Make note of how everything is located. I ripped the gasket removing the rubber grommet for the stator wires but it might be better to slice it with a razor instead if you plan on reusing it. Either way a little bit of sealant will fix it up without a new gasket. Remove the three bolts hold the stator to the cover and the two holding the signal generator. You'll want to put the screws back in their holes after you have the stator out so you don't mix them up or lose them.
Baja Designs 250W Stator install SDC10026
Waiting: May as well reassemble everything while it's fresh in your mind where it all goes. The fasteners don't need to be tight or torqued down as it won't be running without a stator anyway! It'll be a week or two at least before you get the stator back to re-install it. I left the shifter off as that one's pretty obvious where it goes, but I put the bolt back into it so I don't lose it.
Baja Designs 250W Stator install SDC10027
Shipping: Ready to ship out! A gallon size zip lock bag works well keeping it tidy.
Part 1 complete! More to come when re-installing.....
Baja Designs 250W Stator install Empty Making the puzzle pieces fit....
Post  Guest Sun Apr 08, 2012 6:24 am
While waiting for my stator to come home I thought I'd try fitting some bits and pieces into their new homes.
Before moving things around:
Took out the AC regulator as I'm going all DC and it's being replaced with the RickyStator 250W reg/rec. So the CDI moved to the AC reg spot. Just loosening the airbox bolt allowed it to slide in there and with the rubber sleeve around it still has some vibe damping. Tighten the bolt and it's locked in there. The Battery lays in the CDI's old spot nicely and has plenty of clearance. The fuse box goes in the spot the wire connector cluster sat in. Plenty of room under the side cover for the connectors and wires.
Baja Designs 250W Stator install Puzzle1
This is a fusebox I had laying around from extra stuff pulled off an old bike of mine. Should work PERFECT!
Baja Designs 250W Stator install Fusebox1
Forgot I needed a place for the RS reg/rec so the fusebox had to go elsewhere. The old bolt was too short and the AC regulator bolt that was removed is about 1/4 inch too long, a small stack of washers fixes that.
Baja Designs 250W Stator install Puzzle2
Where the fusebox ended up, not ideal but accessable if you loosen the clamp:
Baja Designs 250W Stator install Fusebox3
That's all for tonight! Smile
Last edited by DirtyErnie on Mon Apr 09, 2012 4:48 am; edited 1 time in total (Reason for editing : lack of proof reading!)
Baja Designs 250W Stator install Empty Can BD stator run as single output?
Post  Guest Mon Apr 09, 2012 4:59 am
I know the RS stator can be hooked up as a single output like this picture. Any reason a BD stator can't be hooked up the same way?
Baja Designs 250W Stator install RS%2520single%2520output%2520stator%2520setup%2520001
This is what I'm planning:
Baja Designs 250W Stator install One%2520output%2520250w%2520diagram%2520XR650R
Larger Version of Diagram
Baja Designs 250W Stator install Empty Re: Baja Designs 250W Stator install
Post  Guest Mon Apr 09, 2012 5:00 am
hmmm... diagram was supposed to be bigger...
Post  Focker Mon Apr 09, 2012 5:55 pm
DirtyErnie wrote:hmmm... diagram was supposed to be bigger...
I have a image size limit set...Link it to a larger pic where it's hosted for those who need to zoom. listen up
~Focker
Focker
Focker
Site Owner
http://www.xr650rforum.com
Post  Guest Mon Apr 09, 2012 7:38 pm
Since you're going all-DC, this might be helpful. This is the wiring diagram I made for my XR-R.
Baja Designs 250W Stator install Actualwiringrevised
Link to full-size image: https://2img.net/r/ihimizer/img600/2735/actualwiringrevised.png
Baja Designs 250W Stator install Empty High Beam LED
Post  Guest Mon Apr 09, 2012 9:19 pm
I presume that's the K&S 12-0055 switch? Have you had it hooked up yet like this? I was trying to figure out how that LED terminal was supposed to wire in! Thanks! Smile
Post  Guest Mon Apr 09, 2012 10:17 pm
DirtyErnie wrote:I presume that's the K&S 12-0055 switch? Have you had it hooked up yet like this? I was trying to figure out how that LED terminal was supposed to wire in! Thanks! Smile
I haven't wired it up yet, no. I based the wiring off of a .pdf instruction sheet I found for it, showing the wiring colors. It showed one of the leads as "Headlight Hi-Beam LED (wire to Ground)" or something to that effect, which tells me it is connected internally to the white (high-beam) output, and then needs a ground to light up.
Post  Guest Mon Apr 09, 2012 10:20 pm
Oh, guess I'll post this up too. I modified the previous wiring diagram to include the ProCycle ignition/kill switch. Also, as a side-note, there's an error in my previous wiring diagram (I'll try to edit it). The high-beam output from the handlebar switch should also be connected to the rear running light (using a diode to isolate the high and low-beam circuits from each other).
Baja Designs 250W Stator install Actualwiringrevisedswit
Direct link: https://2img.net/r/ihimizer/img856/5107/actualwiringrevisedswit.png
Post  Guest Tue Apr 10, 2012 4:45 am
I think my running light will be on any time the key is. I can't think of any reason I'd turn it off when riding though so not a problem. Got a few more parts in today, the DRC LED taillight insert, rear signals and license light.
The LED insert came with tiny screws and washers that were bound to vibrate loose if not loctited. I went a different route. naughty
Baja Designs 250W Stator install Image004(yes, rivets)
And the new turn signals:
Baja Designs 250W Stator install Image018
Tested them with the new battery and was happy with the brightness of them all.....
Baja Designs 250W Stator install Empty Stator update
Post  Guest Sat Apr 14, 2012 1:07 am
I don't know what the hell happened between the time I dropped the stator with the motorcycle shop to ship to BD for rewind and now. I just got in touch with BD directly today and they just got the stator yesterday! I gave the shop my stator like two weeks ago!! beat head angry censored Frustrated
Anyway, the good news is even though I couldn't get them to answer a simple question:
"Can the stator be wired in (at the harness) for one 200W output when the stator is wound for two 125W outputs?"
Is that a confusing question for someone who deals with stators day in and day out??
They are winding it for a single output. Hopefully I won't need a second winding as a backup somewhere down the road. shrug
I got my handlebars and brake switches today and priced a couple of things for the bike in the future at NAPA. I'm thinking a couple of these would work well as off road aux fork mounted flood lights:
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=BK_7355799_0361153365
Baja Designs 250W Stator install 256061
At $12 a piece I wouldn't shed too many tears if I bust one. I have trail tested these on another rig I had, don't laugh, I horse traded for it and pieced it together for next to nothing and it worked great! Smile
Baja Designs 250W Stator install Quad1
Baja Designs 250W Stator install Empty Progress..
Post  Guest Fri Apr 20, 2012 1:23 pm
I've got my wiring harness made up and installed but still waiting on parts to finish things up. Pics to follow soon.....
Baja Designs 250W Stator install Empty more parts in!
Post  Guest Tue Apr 24, 2012 1:22 pm
Got my package from HDB yesterday. Have the guards installed with buttons, mirrors, blinkers, horn and flasher relay. Pretty much all that's left is the stator which is supposed to get here this week. Yeah!!!
Baja Designs 250W Stator install Empty BD Stator install
Post  Guest Sat Apr 28, 2012 3:42 am
A picture is worth a thousand words...
Baja Designs 250W Stator install Rewound%2520stator
Supa-fresh rewind
Baja Designs 250W Stator install Grommet
Yes, they even use the grommet...
Baja Designs 250W Stator install Install%2520stator1
Ready to assemble, printed out instructions but ended up not needing them. Far as I can tell the extra clearance is not needed when wound as a single output. I carefully checked before bolting it all up! 2 thumbs
Baja Designs 250W Stator install Gasket%2520fix
Fixing the rip in the gasket with a dab of silicone, should be fine....
Baja Designs 250W Stator install Stator%2520in%2520cover
Signal generator and wire cover in place.
Baja Designs 250W Stator install Back%2520together1Baja Designs 250W Stator install Wires%2520run
Routing the wires in the stock locations...
Baja Designs 250W Stator install Wire%2520hookup
The long White/Yellow and Dark Green pair went to the AC reg, the Brown/Black and Dark Green pair went to the tail light and the White/Tan and Light Green are the new stator winding and go to the two yellow wires coming from the Reg/Rec (w/wirenuts and no there are no wirenuts used in my wiring, just temp caps in this pic!) Ultimately the White/Yellow, Brown/Black and the (Blue?) for the AC headlight (not in picture) all connect together elsewhere in the harness and are no longer used. I connected the White/Yellow and Brown/Black together and the two Dark Greens together and taped and tucked them into the cover, out of the way. The other wires here are pretty straight forward.
Last edited by DirtyErnie on Sat May 05, 2012 5:33 am; edited 1 time in total (Reason for editing : Added info)
Baja Designs 250W Stator install Empty Done! (for now...)
Post  Guest Mon May 14, 2012 11:09 pm
I've got it in working order. There are a few things I'd like to tidy up later on down the road. But right now I want to go ride!! I need to get rid of the massive wiring and connector lumps under the seat and behind the headlight. The biggest problem I had was not being able to find any OEM style connectors in town and just made due with bullet and blade connections. So it's a little sloppier than I would have liked but it all works.
Baja Designs 250W Stator install SDC10107
Baja Designs 250W Stator install Hdb2
And how she sits now:
Baja Designs 250W Stator install Afterrack2
Baja Designs 250W Stator install Empty Trail tested 200 miles!
Post  Guest Fri Jun 01, 2012 4:19 am
She's been throughly tested and everything works great, no blown fuses, melted wires or dark rides home! (so far...)
Baja Designs 250W Stator install Sno%2520parking
