My SM Project, DONE!
My SM Project, DONE! Empty My SM Project, DONE!
Post  Guest Fri Apr 13, 2012 3:14 am
2001 XR650R Street Legal SM I started this project 2 years ago and now that it is done, time to sell. lol
Blue Plated and clear street title
My SM Project, DONE! MyXR650R
Body
Acerbis SM black front fender
Larger black gas tank
shortened kick stand to accommodate shortened seat height
modified side covers to follow a smooth line without number plates
new black textured seat cover
Acerbis SM headlights
Acerbis signal lights
Acerbis tail/braking light kit
Modified rear fender
My SM Project, DONE! IMG_3230
Controls
Custom carbon fiber dash
Answer oversized bars
superbike grips
Acerbis high/low/horn/signal controls
GS 1150 mirrors
modified CR500 triples for fat bars
Baja designs Banjo brake light switch front & rear
Acerbis bark buster hand guards
Yosh push/pull throttle assemble
Horn
My SM Project, DONE! IMG_3219
Drive
Moose 14 tooth counter shaft sprocket
KUSH 40 tooth rear sprocket (like having an actual cush drive!)
DID 520 gold o-ring chain
My SM Project, DONE! IMG_3227
Engine
Wiseco high compression piston
BarnumsPro Stage 1 cam
Ported and polished head
Flo stainless steel performance oil filter
All rad hoses replaces with blue CS3 silicone hoses
My SM Project, DONE! Picture148
Exhaust
Leo Vince stainless full performance exhaust system
My SM Project, DONE! IMG_3193
Intake
Keihin FCR 41mm pumper carb
Unifilter external filter
My SM Project, DONE! Picture150
Suspension
Showa inverted forks shortened & re-valved for SM
Racetech fork springs
Elka custom fully adjustable rear SM racing shock with remote reservoir
Eibach spring
All Balls complete bearing rebuild kits for every bearing on the bike
My SM Project, DONE! Picture153
Wheels & Tires
Behr 17″ x 3.5″ black front SM rim
Behr 17″ x 4.5″ black rear SM rim
RAD heavy duty stainless steel spokes
RAD HEX series front & rear hubs two-tone red & blue
New Dunlop SportMax GP racing tires
My SM Project, DONE! IMG_3204
Brakes
Braking SM front master
Braking SM front calliper
Motomaster 320 mm front rotor
Braking rear rotor
front and rear steel braided brake lines
front and rear Speed Bleeders
My SM Project, DONE! IMG_3239
Electrical
Ricky Stator Dual stage 200 watt stator
Key switch ignition
My SM Project, DONE! IMG_3189
Other
modified subframe - eliminated air box
Barnums oil sight tube
Fuel stop, gas cap breather tube
Large capacity radiators
Clutch lever cap for mirror
K&N breather filter
Water temp radiator cap
Steel braided breather hose
Quick release racing fuel line
My SM Project, DONE! IMG_3200
More info here: footankle.ca/XR650R
If it doesn't sell I will part it out.
My SM Project, DONE! IMG_3223
thanks for looking...
Very Happy
My SM Project, DONE! Empty Re: My SM Project, DONE!
Post  Guest Fri Apr 13, 2012 5:48 am
Sounds like it is put together well, visualizing a lot of farkling dollars.
Post  Mauser Fri Apr 13, 2012 8:11 am
My SM Project, DONE! Useless
Post  Guest Fri Apr 13, 2012 3:04 pm
All this excitement and no pictures!!
I'm Sad Frustrated
Post  Guest Sat Apr 14, 2012 1:00 am
Ok, got some pictures. Whew, not good ones but better ones will come. Thanks.
Post  Guest Fri Apr 27, 2012 9:52 pm
Shoo.. very nice
Post  Guest Sun Apr 29, 2012 4:14 am
nice
Post  Guest Mon May 14, 2012 10:15 am
You ever sold it?
My SM Project, DONE! Empty Nope
Post  Guest Sun Mar 10, 2013 2:03 am
He hasn't sold it yet;
http://toronto.kijiji.ca/c-cars-vehicles-motorcycles-sport-bikes-2001-Honda-XR650R-Supermoto-Superbike-W0QQAdIdZ361826438
I looked at his listing a few times but passed, not quite what I wanted.
My SM Project, DONE! Empty Killer bike!
Post  Guest Sun Mar 10, 2013 3:03 am
Wow! Nice job man. Bump
My SM Project, DONE! Empty Question for OP
Post  Guest Thu May 16, 2013 6:18 pm
Nice job but I have to ask if there is a reason the alternator and clutch covers were not refurbished?
Post  Guest Sat Sep 07, 2013 2:27 am
Nice work Smile unique look
