Gas coming out of over flow tube
Post  thumprr on Wed Oct 10, 2012 12:26 am
Hello. I cranked my 2006 XR650R today for the first time since I had knee surgery. My bike cranked easy enough. Now I have gas coming out of the over flow tube? It ran good and idled after it warmed up. I assume my float is stuck? Thanks in advance for any help. The gas is running out even when not cranked if I have gas turned on. Frustrated
thumprr
XR650R Year : 2006
Re: Gas coming out of over flow tube
Post  Mauser on Wed Oct 10, 2012 7:59 am
Does sound like your float jet not sealing....maybe your fuel has gone old and blocked it...sounds like a strip down or switch fuel off drain the bowl and remove it.....you might be able to clear the seat without removing the carb....?
How long has the fuel been in there ?
Post  SkidMark on Thu Oct 11, 2012 2:24 pm
sounds like your float is stuck - before disassembling just try a couple of good taps with the handle of a hammer. Might just be stuck once and be fine afterwards. Otherwise follow advice above.
Regards
Post  rikco on Thu Oct 11, 2012 6:11 pm
open petcock vew seconds, close it again, start motor until it almost run out of gas you open the petcock again. do that a vew times and most of the time its ok again if its not stuck to much ofcourse.
tapping the gaschamber works also many times
rikco
Post  SF Native Hooligan Rider on Sun Mar 10, 2013 4:21 pm
rikco wrote:open petcock vew seconds, close it again, start motor until it almost run out of gas you open the petcock again. do that a vew times and most of the time its ok again if its not stuck to much ofcourse.
Thanks for the advice, Rikco. Tapping wasn't working, but your method worked after repeating the process about 15 times.
Post  rikco on Sun Mar 10, 2013 4:27 pm
nice Bananatool
good work cheers
rikco
Post  Zoro on Mon Mar 11, 2013 3:58 am
Would be a good idea to remove the carb and give it a clean out though.
If there was enough crap in there to stick the float assy then there'll be enough crap in there to block a jet, surely.
Especially if its been sitting around for some time.
Just my 2 cents.
Zoro
Thanks Zorro
Post  SF Native Hooligan Rider on Mon Mar 11, 2013 4:10 am
Good point. It has been sitting, so I'll follow your advise.
