Front wheel spacers
Front wheel spacers
Post  carlgustav on Sun Dec 30, 2012 10:26 pm
So, my 'new to me' XR came with both motard street wheels and the off-road wheels. I went to put on the off-road wheels and found that I only got one spacer. Apparently there was a speedometer housing (?) on one side that acts as the other spacer, and this I don't have. Do I have to buy a speedo housing, or is there some other less xpensive spacer option? TIA.
ACE
carlgustav
XR650R Year : 01
Re: Front wheel spacers
Post  SkidMark on Mon Dec 31, 2012 7:07 am
its common for people to remove the factory speedo drive and install acewell or trailtech speedo's. XR's Only do a spacer you can install but its kinda pricey:
http://www.xrsonly.com/parts-manufacturers-a-g-1/al-baker-xr-only/wheel-spacers/xrs-only-quick-change-front-wheel-spacer-speedo-drive-replacement-honda-xr650r
I would machine one up myself but depends on if your in the right job or have the right friends... Wink
Cheers
Mark
Post  Mauser on Mon Dec 31, 2012 9:35 am
"If" I ever change my speedo to a Trailtech I will keep the stock speedo drive and fit a mechanical to electrical converter behind the clocks....I think the crappy magnet is a terrible idea which looks dreadful.
Post  Mad Frosty on Mon Dec 31, 2012 11:24 pm
I am wondering if the baja designs DS kit ( lights , indicators , horn ,... blah ) fits on the european model xr 650 r because we have the massive speedo clock thingy , does anyone know if it fits ok , or some modifications are needed ?
Post  Mauser on Tue Jan 01, 2013 1:46 am
Mad Frosty wrote:I am wondering if the baja designs DS kit ( lights , indicators , horn ,... blah ) fits on the european model xr 650 r because we have the massive speedo clock thingy , does anyone know if it fits ok , or some modifications are needed ?
What is your bike missing frosty ?, should have everthing fitted ?.....
Post  carlgustav on Tue Jan 01, 2013 3:00 am
@Skidmark,
That's for both side spacers, looks like I can get just the speedo side for $18.95 ... maybe worth it to avoid a hassle. I found a front wheel spacer kit by All Balls at Motosport for $10.99, but I'm not sure that the speedo side will work correctly ...
ACE
carlgustav
XR650R Year : 01
Post  Mad Frosty on Tue Jan 01, 2013 7:28 pm
The main light unit its ugly and the bulb its a joke , even most basic h4 bulb gives loads more light , also i have no indicators ( the bike used to have them but some of us use the xr offroad you know asking for it ) , and the rear light is rattling and i like the look of the BD LED setup much more , so the only question holding me back is the compatibility issue Bananatool
Post  Mad Frosty on Tue Jan 01, 2013 7:30 pm
Oh and i dont want to go the trailtech route .
Post  Mauser on Tue Jan 01, 2013 8:14 pm
Mad Frosty wrote:Oh and i dont want to go the trailtech route .
Well your stator should be good enough for a decent light ?, indicators should should just connect up ?.
I have the single tail light on the fender which I converted to run a twin LED for stop/tail and added a hydraulic pressure switch to activate.
Post a picture of your bike so we can see whats wrong with her Smile.
Post  Mad Frosty on Wed Jan 02, 2013 8:54 pm
She is not ready for photosession yet , give me more time naughty
