Rear Shock...from 2000 to 2007
Post  babuja on Sun Apr 21, 2013 9:23 pm
Hi guys,
need some help to confirme if rear shock is the same from 2000 to 2007.
Tnks
babuja
Re: Rear Shock...from 2000 to 2007
Post  Mad Frosty on Mon Apr 22, 2013 12:01 am
Yes .
Post  babuja on Mon Apr 22, 2013 7:48 am
Mad Frosty wrote:Yes .
Tnks Mad Frosty nice
babuja
Post  BuRP on Mon Apr 22, 2013 11:40 am
It is, most of the bike in fact.
Mounting a correctly rated spring for you though (you're sending git out don't you?) would be a good idea, ditto doing the Borynack mod.
Post  babuja on Mon Apr 22, 2013 2:17 pm
BuRP wrote:It is, most of the bike in fact.
Don't have time for Borynack mod...maybe next time. "git"?
babuja
Post  BuRP on Mon Apr 22, 2013 7:35 pm
git = it, speling iz nod my forte it seems
I have done zilch at the rear yet, so I am the last to tell you different - but a friend of mine only did his shock recently, and regrets now that he didn't do it as his first mod!
Post  babuja on Fri May 10, 2013 12:04 am
BuRP wrote:git = it, speling iz nod my forte it seems
BuRP wrote:... friend of mine only did his shock recently, and regrets now that he didn't do it as his first mod!
You mean changing shims and spring as sheet? Or gold valve too? What setup did your friend go for?
babuja
Post  BuRP on Fri May 10, 2013 11:07 am
He did the Borynack mods front & rear.
The front involves drilling 2 (out of 4) holes bigger, different shims & thinner oil (2.5 weight if memory serves well).
The shock is shimmed different, quite so actually, and I can't remember drilling of anything. As said, especially the shock makes a huge diff apparently.
If Borynack's site is inactive (it sometimes it) then I can mail you the info, just holler Wink
Oh (edited), if you still have the original fork-oil in, nicknamed "whale snot", then replacing only this with real forkoil is already a good improvement. But, flush the forks quite well to get all the snot out, and check for rust inside as also this is not too uncommon to find!
Post  babuja on Fri May 10, 2013 11:45 am
hi mate, about forks i just did crf showa conversion...about rear shock i've gomy hands on a use3d one and i' ll prepare then too...just need some infos to find the best way to go. tnks man Wink
babuja
