upper tree
upper tree
Why do people change the upper tripple tree? Mine has a BRP brand tree with Renthal bars. I think
the risers are stock...
Thanks!
Scott
Thanks!
Scott
Re: upper tree
Your risers are not stock because they are built into the stock upper triple clamp. This is why they are often changed, because people want to move the bars, raise them, or install tapered bars. FYI
Re: upper tree
PeteN95 wrote:Your risers are not stock because they are built into the stock upper triple clamp. This is why they are often changed, because people want to move the bars, raise them, or install tapered bars. FYI
also some steering dampers require this to be replaced.
» XR650R Upper Engine Rebuild Part 1: Tear Down How to
» Michigan Upper Peninsula Dual Sport Trip
» 2002 CRF Triple Tree - Differences between 450/250/125?
» Renthals bars 7/8 on stock tree can be done?
