Acerbis tank dimensions
Post  SkidMark on Thu May 23, 2013 11:34 am
Could someone with an Acerbis tank give me the dimensions of it, ie what size box I would need to ship one.
Re: Acerbis tank dimensions
Post  BuRP on Fri May 24, 2013 8:13 am
XL
Post  Mad Frosty on Fri May 24, 2013 4:59 pm
YOU want the size of the original box , the tank comes in ? or the dimensions of the tank ? ( i am just making sure that i know what you want , sorry )
Post  SkidMark on Sun May 26, 2013 10:20 am
MF - If you can give me both that would be great otherwise just the actual tank would be good. I hear the original box is a bit on the large size.
Thanks for your help BuRP ... beat head
Last edited by SkidMark on Mon May 27, 2013 4:22 am; edited 1 time in total (Reason for editing : correction)
Post  Mad Frosty on Mon May 27, 2013 7:12 pm
The tank
22 inches wide ( 56cm )
20 inches high ( 51cm )
22 inches long (56cm )
I have rounded the numbers a little as the measuring is not easy because of the shape of the tank , the real size will be 1 or 2 milimeters less , 22inch box or bigger will take the tank , but bigger one allows you to add more shock absorbing material/padding .
The original box its much larger , i think its a overkill as there was loads of empty space just filled with buble wrap / baloon bags protective thingies Bump
Post  SkidMark on Mon May 27, 2013 8:23 pm
That's great thanks.
Post  BuRP on Tue May 28, 2013 9:41 am
I don't have the Acerbis, got he IMS - which is larger because it really goes deep - hence my guess BRP smile .
Mind though, I recently received the Safari 44L tank(s, dual full halves), and the size of this behemoth you'll have to see! Box-size XXXXXXXL Bump
