Clutch plate replacement
So I had to replace the clutch plates on my 2001 brp ( there was hardly any thing left of them) I got a tusk clutch kit with ebc springs. For the kit to work I had to remove the judder springs, I found that out the hard way. Anyway with the judders out the clutch works great and the bike is not the same bike! Bt now the problem is that with the clutch pulled in there is kind of a slight metallic sound coming from the clutch that goes away when it grabs.
1. I thought I liked the stock springs better so I put them back in.
2.im thinking without the judders it made the pack thinner making more room for the plates to wiggle.
Any ideas? I'm scared of riding the bike untill I know everything is good.
Ps no metal shavings or anything and I double checked to make sure all the parts were there.
Last edited by Dirtautoguy on Sat May 25, 2013 7:14 am; edited 1 time in total (Reason for editing : Spelling error)
Re: Clutch plate replacement
I always thought the clutch set-up was determined by the stack height, the book should give you a spec for max and min height of the stack, I would work within the spec.
I thought, with the judder removed, you were supposed to add another plate or disk, forget which. I believe you add an extra steel clutch plate.Mauser wrote:I always thought the clutch set-up was determined by the stack height, the book should give you a spec for max and min height of the stack, I would work within the spec.
I'd have to take mine apart and count to verify as I did this many years ago. OK, coulda been yesterday and I'd forget.
Your probably right I'm just saying the finished stack height is importantdougc wrote:I thought, with the judder removed, you were supposed to add another plate or disk, forget which. I believe you add an extra steel clutch plate.Mauser wrote:I always thought the clutch set-up was determined by the stack height, the book should give you a spec for max and min height of the stack, I would work within the spec.
» Extra metal clutch plate mod
» Head Bolt Pattern Measurements & Clutch Plate Thickness
» Stock headlight replacement
» Spoke replacement
» front fender replacement
» Spoke replacement
