Fuel Tap Rubber
Fuel Tap Rubber
Post  Mauser on Thu Jun 20, 2013 8:29 am
Anyone have a source to replacement washers ?, mine seems chewed slightly; I have turned it over but other side seems as bad ?, bike seems to run till nearly out of gas without hitting reserve I can only think it's leaking through the tap and drawing fuel from the reserve section ?.
Would have thought it would be a spare part as the tap is screwed together but cannot find any info on the seal ?.
Re: Fuel Tap Rubber
Post  BuRP on Thu Jun 20, 2013 5:08 pm
Search here http://advrider.com/forums/showthread.php?t=409774&page=1157
and start searching ~30 pages back.
You'll find alternative Honda gaskets which fit and are normally available!
Re: Fuel Tap Rubber
Post  BuRP on Thu Jun 20, 2013 5:22 pm
"bike seems to run till nearly out of gas without hitting reserve I can only think it's leaking through the tap.."
Not necessarily. If a hole develops in the pipe (brass?) within the mesh then it will do same - and I have seen pics of this! Re-check?
Re: Fuel Tap Rubber
Post  Mauser on Thu Jun 20, 2013 6:36 pm
BuRP wrote:"bike seems to run till nearly out of gas without hitting reserve I can only think it's leaking through the tap.."
I know about the hole in the brass Burp... I have pictures of my own lol.
Will have a look through the link Smile.
Re: Fuel Tap Rubber
Post  BuRP on Fri Jun 21, 2013 9:59 am
If any holes then solder them shut - that is if small enough. Otherwise a very thin brass sheet/strip (ask your friendly model plane/car vendor for such) shaped over it can be soldered.
The trick is cleaning well and applying the proper flux to both parts prior to heating, that's all. Oh, clean & rinse VERY well afterwards.
Re: Fuel Tap Rubber
Post  Mauser on Tue Jul 09, 2013 7:04 pm
Here you go the seals which according to another forum fit the piggy.....
Part #'s 16955-HA2-005 4 hole gasket. and part# 16963-HB9-005 x-ring.
Re: Fuel Tap Rubber
