Another problem, too little oil in gearbox ... after rebuilt
Page 2 of 3
Page 2 of 3 • 1, 2, 3
Re: Another problem, too little oil in gearbox ... after rebuilt
But the picture you have shown is NOT a 650R clutch cover or 650L cover....confusedChris_w_65 wrote:I see the bolt in your cover - turn it around and you will see the head and sealing washer
Mine is same as yoursMauser wrote:But the picture you have shown is NOT a 650R clutch cover or 650L cover....confusedChris_w_65 wrote:I see the bolt in your cover - turn it around and you will see the head and sealing washer
My casing has an independant gold coloured clutch cover that can be removed - yours looks like a one oiece unit - Mine is a 2003
What is that bolt about 35mm above the kichstart bearing? Mine looks worn so I ordered one. Honda lists it as a special bolt. 90041-MBN-670Mauser wrote:Am I missing something here......here is my clutch cover ?.
Don't look like anything above
And here's the 650L cover....
I see you also have a removable magnesium cover - it says so on the inside just like mine.Chris_w_65 wrote:My casing has an independant gold coloured clutch cover that can be removed - yours looks like a one oiece unit - Mine is a 2003
Speaking of clutch covers - I am going to get gold paint matched - it is automotive Kapsci body paint + premium hardener - Will it stand the heat?Chris_w_65 wrote:I see you also have a removable magnesium cover - it says so on the inside just like mine.Chris_w_65 wrote:My casing has an independant gold coloured clutch cover that can be removed - yours looks like a one oiece unit - Mine is a 2003
I have no idea never messed with it....you have still not explained why the picture shown is not a 650R clutch cover ?......Chris_w_65 wrote:What is that bolt about 35mm above the kichstart bearing? Mine looks worn so I ordered one. Honda lists it as a special bolt. 90041-MBN-670Mauser wrote:Am I missing something here......here is my clutch cover ?.
My photo is taken from the outside - yours is from the inside
Makes sense if your scavenge pump were faulty oil would run out of it
Hew your a pretty normal guy tell the others that the picture of their clutch case isn't a 650R it's from another bike !!!!
'Course it is, just take the cover off the cover...
Or look at the hondaparts-direct.com link I posted higher up with the part numbers:bananatool:BuRP wrote:'Course it is, just take the cover off the cover...
I must be losing the plot, I didn't realise and even looking at the drawings that the right crank case cover is in 2 parts, the main section which is clearing shown on the drawing and the rear part which doesn't seem to have a part number ?.
I appologise to you all for being a noob and will shut up for the next 12 hours....
I was starting to think you had a Chinese knock off (Chonda XR650R) parked in your garageMauser wrote:I must be losing the plot, I didn't realise and even looking at the drawings that the right crank case cover is in 2 parts, the main section which is clearing shown on the drawing and the rear part which doesn't seem to have a part number ?.
Nope, but Mauser drinks tea Chris, so I suspect he had a bit of an alien leaf in there...
No worries Maus', I've been seen pouring coffee in the sugar, we all have blonde moments. And don't overdo it pls, 12 hours is a looong time to go celibate
Hey Mauser - The kickstart fell off the XR650L I am riding at the moment - Do you know where I can get one?
Can someone send me a link to the part number for this cover in question as my online source doesn't show it.....?Chris_w_65 wrote:Hey Mauser - The kickstart fell off the XR650L I am riding at the moment - Do you know where I can get one?
Here you go - part 1 and part 4Mauser wrote:Can someone send me a link to the part number for this cover in question as my online source doesn't show it.....?Chris_w_65 wrote:Hey Mauser - The kickstart fell off the XR650L I am riding at the moment - Do you know where I can get one?
28 is the supposed scavenge oil level check plug
Number 20 is a special bolt I am changing - It has something to do with kickstart I think - mine is a little worn - Anyone know its purpose?
http://www.hondaparts-direct.com/fiche_section_detail.asp?section=2691614&category=Motorcycles&make=Honda&year=2003&fveh=134983
It would be realy interesting, if anyone with a XR650R can turn this ominous screw out (maybe one with 17inch wheels in front).
When I do this, there is no drop of oil coming out - whether when it runs nor when its cold - still afraid, contacted Clymer now conc. this problem - wait for answer now.
Can anyone turn out this bolt and give me notice, isn't much work. If necessary, I can make a picture, where this bolt is located.
I think Bolt20 is either the hookup for the kicker's spring or the stopper for the toothed cam?
Grizzly, being Austrian is no excuse for being stubborn and not wanting to learn. I'll tell you for the last time, this bolt does nothing - but maybe you didn't read Hew's post?
Over & Out on this subject for me.
» No reserve problem & fix
» Gearbox noise
» GEARBOX---gear fork issue help!
» Problem with oil
» AZ...South Rim, Grand Canyon
» Gearbox noise
» Problem with oil
Page 2 of 3
