Another problem, too little oil in gearbox ... after rebuilt
Page 3 of 3 Previous  1, 2, 3
Re: Another problem, too little oil in gearbox ... after rebuilt
Post  BuRP on Mon Aug 19, 2013 7:04 pm
I think Bolt20 is either the hookup for the kicker's spring or the stopper for the toothed cam?
Grizzly, being Austrian is no excuse for being stubborn and not wanting to learn. I'll tell you for the last time, this bolt does nothing - but maybe you didn't read Hew's post?
Over & Out on this subject for me.
Post  grizzly on Mon Aug 19, 2013 7:36 pm
Not stubborn but still can't get the manual from clymer out of my head, it is written for a XR650R and I'm still afraid because clutch discs not running in oilbath (maybe), hope You're not angry Frustrated
edit: here's a pic, where the ominous bolt is located (end of the green arrow):
grizzly
XR650R Year : not yet
Post  Chris_w_65 on Mon Aug 19, 2013 8:51 pm
grizzly wrote:It would be realy interesting, if anyone with a XR650R can turn this ominous screw out (maybe one with 17inch wheels in front).
When I do this, there is no drop of oil coming out - whether when it runs nor when its cold - still afraid, contacted Clymer now conc. this problem - wait for answer now.
Can anyone turn out this bolt and give me notice, isn't much work. If necessary, I can make a picture, where this bolt is located.
Put your front wheel on a 2" block of wood - problem solved Bump
Chris_w_65
Post  Mad Frosty on Mon Aug 19, 2013 11:13 pm
grizzly , forget about the screw trust me , btw what is the thingy under your radiator ?Question
Post  Mauser on Tue Aug 20, 2013 9:35 am
Mad Frosty wrote:grizzly  , forget about the screw trust me , btw what is the thingy under your radiator ?Question
Oil cooler listen up ......don't tell me your bike don't have 1 Frosty ?
Post  Chris_w_65 on Tue Aug 20, 2013 9:49 am
I want one - Where can I get it? Apart from cooling there is probably a small gain in oil capacity Very Happy
Chris_w_65
Post  grizzly on Tue Aug 20, 2013 3:02 pm
This "thingy" is an oilcooler from the previous owner. I myself never would spend an idea to give a watercooled bike an oilcooler, think it's needless ...
Yes, it needs 0,2 Liters more oil - for example after oil change 1,8 liters, after rebuilt 2,0 liters ...
oilcooler You can get in Germany here:
http://www.abp-racing.de/%C3%B6lk%C3%BChler/
grizzly
Post  Mad Frosty on Tue Aug 20, 2013 9:19 pm
That is exactly what i think Chris , increased oil capacity sounds good to me as long as the oil pump can hold the oil flow , i want one .
Post  Womble on Tue Aug 25, 2015 7:44 pm
So I'm a couple of years late to this thread.
I read this page in my manual and felt obliged to share it here:
Mine is a 2001 U Model (Australian)
Womble
Post  BuRP on Wed Aug 26, 2015 10:08 am
FOCKER........ please Moderate Mauser????????
BRP smile
You're confusing the hellouta us mate, that screw does zilch!
Even the Honda manual is wrong, it simply does not make sense... so leave it.
Drain frame & sump, fill frame until full (around 1.5 liters), start, let idle, then top-up the oillevel in the frame so it is 'level' on the dipstiock, then switch off.... finished!
No screwing around with fiddly screws diehards don't even know about, deal? Bump
Post  Chris_w_65 on Wed Aug 26, 2015 2:56 pm
Rather 1.4lt or a bit less then kick the bike over a few times and add more, I made the mistake of trying to fit more in the frame and the oil overflowed out the frame beat head beat head beat head
https://www.youtube.com/watch?v=Q9t14IK69r8
Chris_w_65
Post  BuRP on Wed Aug 26, 2015 3:36 pm
Re-read again pls?
"Drain... and sump, ...." and you didn't do that bit! BRP smile
Post  Chris_w_65 on Wed Aug 26, 2015 5:31 pm
With the service intervals on the BRP I am getting lots of practice - 1800km done and almost due for 3rd service already
Chris_w_65
