Help rear shock!
Help rear shock!
Post  brapercise on Sat Aug 17, 2013 10:53 pm
So I took my new to me xr out and turns out it has no rear shock mud flap it was caked in wet sand will I be ok? I don't want to have to rebuild it so soon.
brapercise
brapercise
Re: Help rear shock!
Post  Mauser on Sun Aug 18, 2013 12:04 am
Wash it down with a hose pipe not high pressure and then dry it and spray some WD40 on the shock.....then get a new flap from Honda they are cheap !!!
http://dealers.ronayers.com/ProductDetails/N/687/SKU/271666
Post  brapercise on Sun Aug 18, 2013 1:06 am
Thanks think I hurt it? Do these have seals like the front
brapercise
brapercise
Post  BuRP on Sun Aug 18, 2013 7:19 am
Yah but no worries, just clean it like Maus' said and all will be fine. This is a dirtbike, so even with the flap it will get filthy from time to time. Check for it leaking/sweating oil, that's all.
Post  Mauser on Sun Aug 18, 2013 9:30 am
brapercise wrote:Thanks think I hurt it? Do these have seals like the front
There should be a front wiper seal before the main seals this is to clean away all the crap that gets chucked on there same principle as the front fork seals....Smile
spring sock?
Post  DirtyErnie on Sat Jan 03, 2015 5:00 am
I think they make a sock or boot that goes over the spring to keep the shaft and seals clean and dry on the shock. Anybody try one of these and if so where'd you get it and part number etc? I trashed my splash flap with a paddle tire and another flap will suffer the same fate. naughty
DirtyErnie
DirtyErnie
XR650R Year : 2006
Post  Mauser on Sat Jan 03, 2015 8:40 am
Might be easier to make your own sock ?.....maybe with a zip down the length ?....
Post  PeteN95 on Thu Jan 22, 2015 11:17 pm
You could try adding a couple links to your chain to move the rear axle back, it might save your flap?
PeteN95
PeteN95
XR650R Year : '02
Post  DirtyErnie on Mon Jan 26, 2015 6:56 pm
PeteN95 wrote:You could try adding a couple links to your chain to move the rear axle back, it might save your flap?
If I had a couple brain cells rattling around in there I would have done that. It's still there now just a bit shredded.
DirtyErnie
DirtyErnie
XR650R Year : 2006
