Crank counterbalance gear removal
gear removal
two meathods- get a bearing seporater, this can be tricky to use if the cog is very close to the crank, - make up two pieces of flat bar with holes drilled so that the bars can be used to pull the cog off shaft, like a harmonic balancer puller
» 1st Gear
» XR650R engine power output
» Dakar Dual-Sport Kit Removal?
» Clutch basket removal without fancy tool
» Tech Help XR 650 R
