Can I use dot3
Can I use dot3 Empty Can I use dot3
Post  Guest Wed Sep 25, 2013 3:04 pm
Can I use dot 3 brake fluid in the rear brake?
Can I use dot3 Empty Re: Can I use dot3
Post  Mauser Wed Sep 25, 2013 5:22 pm
Will work fine just make sure you get all the DOT 4 out, why would you use 3 when 4 is the norm ?....it won't handle high temps as well ?.
Post  Guest Wed Sep 25, 2013 5:35 pm
Well I put on some sm rims and the rotor was a bit thicker so I bled some fluid and all I have was 3 and I wanted to ride but I just bought some 4
Post  Guest Mon Sep 30, 2013 12:09 pm
Don't mix them, that's all.
