XR650R petcock rubber internals replacement parts
Post  synonymous on Fri Oct 25, 2013 2:03 pm
Hello
Have had a disintegrating petcock for some time and have it fixed now using another article information from advrider. If your petcock is falling apart with little rubber chunks holding your float open etc.... Once you find that for the XR, the petcock is sold as an entire expensive assembly, you can't believe it and search. Here are the two numbers for the 4 hole selector rubber and xring seal for around the selector knob from a TRX that are the parts for the XR as well..
16955-HA2-005
16963-HB9-005
Also, check the app store for an application called pure gas for ethanol free gas in your area to delay this issue in the future
Hope this helps someone
Last edited by synonymous on Mon Oct 28, 2013 1:26 pm; edited 1 time in total (Reason for editing : more info)
synonymous
XR650R Year : 200
