countershaft lateral freeplay
Post  temporary kiwi on Sun Oct 27, 2013 7:11 am
hi all, im wondering if ive got an issue with my countershaft, can someone please check theirs, simply grab the shaft [ with the sprkt on] and see how much you can push it in & out, how much does yours move?, thanks for your efforts
temporary kiwi
XR650R Year : 02
Re: countershaft lateral freeplay
Post  Mauser on Sun Oct 27, 2013 8:15 am
Without looking I would guess mine is 1-2mm Bump
paranoia..
Post  temporary kiwi on Mon Oct 28, 2013 5:05 am
yeah mines 1.45mm, think my notchie gear change was the low oil level, from the oil she's been burning during run in...., might have an issue with glazed bore..
temporary kiwi
XR650R Year : 02
kick start side
Post  temporary kiwi on Tue Nov 05, 2013 2:10 am
just had to tear down my mtr to replace countershaft input bearing, now that i think about it ... i hadnt replaced that one previously as it wasnt avail locally at the time i was rebuilding it, it started off as a noise, then started affecting the driveline as it snatched /released, hadnt caused any gears to be damaged[ could have if i'd left it longer] new bearing arrives tommorow, then it will be a quick reassembly ready to ship down to sth isld on the 15th nov
temporary kiwi
XR650R Year : 02
shift drum stopper cam arm
Post  temporary kiwi on Fri Nov 08, 2013 10:19 pm
temporary kiwi wrote:just had to tear down my mtr to replace countershaft input bearing, now that i think about it ... i hadnt replaced that one previously as it wasnt avail locally at the time i was rebuilding it, it started off as a noise, then started affecting the driveline as it snatched /released, hadnt caused any gears to be damaged[ could have if i'd left it longer] new bearing arrives tommorow, then it will be a quick reassembly ready to ship down to sth isld on the 15th nov
Also at the last minute found ive got a very worn out stopper cam, the pin has been wearing side ways, nearly right thru, + they are'nt in stock in NZ, so im probably going to make one up out of some stainless steel plate
temporary kiwi
XR650R Year : 02
last minute problems
Post  temporary kiwi on Tue Nov 19, 2013 6:48 am
my v/ guides finally arrived , only a week late, got the topend assembled , bike got on a truck 2nite, i fly down to the sth isld 2moro, bike should arrive the next day, then ive got to finish running it in and change the oil/filter ready for 5-6,000kms around south isld of new zealand, will post some pics on my return
temporary kiwi
XR650R Year : 02
