steering shake
Page 2 of 2 Previous  1, 2
tire l won
Post  xr honda to the max on Tue Jun 03, 2014 3:02 pm
hope this helps, can't seem to host a picture on this site now ??!!
mike
xr honda to the max
Re: steering shake
Post  xr honda to the max on Sat Jun 21, 2014 1:53 am
well l installed a new to me rim and tire assemby no more steering shake and go top end , thought it would be faster then what it does , only 160 km ??????!!!!!!!!!!!!, my 500 xr goes closer but not as quick ???????????????!!
how fast is your xr 650 r
mike
xr honda to the max
xr honda to the max
Re: steering shake
Post  Mad Frosty on Sat Jun 21, 2014 8:23 pm
I can only do 70mph over here ( legaly )  BRP smile
Re: steering shake
Post  xr honda to the max on Sun Jun 22, 2014 3:47 pm
Well my big red pig is dead ???????????!!!!!!!!!!!!!!!, balancer blew up sending items through bottom of cases???!!!!!!!!!!!!!!!!!!!!!!!!
Any one with a engine ???????????!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
thanks mike
xr honda to the max
xr honda to the max
Re: steering shake
Post  xr honda to the max on Sun Jun 22, 2014 4:35 pm
lower end con rod blew and piston skirt and items went to the balancer side and through cases??????????????????!!!!!!!!!!!!!!!
not a good day really, like theses XR'S but the old ones will have to doo for now, still have a 79 xr 500 and also a 81 XR5000R
but in time the 2004 will get another engine or find another 650
mike
xr honda to the max
xr honda to the max
Re: steering shake
Post  AURORA on Sun Jun 22, 2014 5:08 pm
Sorry to hear what happened.
So what actually failed causing everthing to let go?
How much oil was in the motor when it let go?
Are both cases bad?
Sounds like a full rebuild with Falicon Rod, Stage two cam 680 kit.
Honda Motorcycle Parts 2004 XR650R A CRANKCASE Diagram
Honda Parts Search: Honda Parts
Manufacturer: Honda Parts
Catalog: Honda Motorcycle Parts
Year: 2004 (View All)
Model: XR650R A (View All)
Component: CRANKCASE (View All)
Parts Microfiche Schematic Breakdown
Zoom inZoom inZoom in
Diagram of Honda Motorcycle Parts 2004 XR650R A CRANKCASE Diagram
Parts List by Blowout Reference#
# Part Number Description MSRP Price Required Qty
Price is for one part. We sell all parts individually.
1 11100-MBN-671
CRANKCASE, R.
$463.62 $305.99 1
Add To Cart
2 11134-MBN-670
COLLAR (12X10)
$1.58 $1.16 2
Add To Cart
3 11145-MBN-670
JET, OIL
$16.31 $10.76 1
Add To Cart
4 11200-MBN-670
CRANKCASE, L.
$485.87 $320.68 1
Add To Cart
5 15220-MBN-670
VALVE ASSY., RELIEF
$22.42 $14.80 1
Add To Cart
6 15421-428-000
SCREEN, OIL FILTER
$14.64 $9.66 1
Add To Cart
7 15515-MBN-670
ORIFICE (1.5MM)
$3.65 $2.51 1
Add To Cart
8 18601-MBW-003
VALVE, REED
$13.60 $8.98 1
Add To Cart
9 22810-MBN-670
LEVER, CLUTCH
$43.62 $28.79 1
Add To Cart
10 22815-MG3-000
SPRING, CLUTCH LEVER
$3.67 $2.53 1
Add To Cart
11 22821-MBN-670
RECEIVER, CLUTCH CABLE
$5.75 $3.86 1
Add To Cart
12 32111-MBN-670
CLAMP, ALTERNATOR WIRE
$4.16 $2.86 1
Add To Cart
13 90004-GHB-630
BOLT, FLANGE (6X16) (NSHF)
$2.87 $2.04 1
Add To Cart
14 90004-GHB-710
BOLT, FLANGE (6X40) (NSHF)
$3.35 $2.37 10
Add To Cart
15 90004-GHB-730
BOLT, FLANGE (6X50) (NSHF)
$2.73 $2.12 2
Add To Cart
16 90004-GHB-770
BOLT, FLANGE (6X70) (NSHF)
$4.45 $3.06 1
Add To Cart
17 90031-MBN-670
BOLT, STUD (12X187)
$5.35 $3.62 4
Add To Cart
18 90131-896-650
BOLT, DRAIN PLUG
$3.32 $2.14 1
Add To Cart
18 90131-883-000
BOLT, DRAIN PLUG (12X15)
$3.32 $2.14 1
Add To Cart
19 90525-GC4-700
WASHER, BRAKE ARM
$1.80 $1.32 1
Add To Cart
20 90751-GK1-003
O-RING (8.5X1.7)
$2.04 $1.44 2
Add To Cart
21 91101-PZ9-000
BEARING, NEEDLE (12X16X10)
$6.89 $4.62 3
Add To Cart
21 91053-719-005
BEARING, NEEDLE (12X16X10) (NTN)
$6.89 $4.62 3
Add To Cart
22 91203-KK3-830
OIL SEAL (14X22X5)
$3.15 $2.23 1
Add To Cart
23 91203-MBN-671
OIL SEAL (34X54X6)
$6.49 $4.36 1
Add To Cart
24 91204-KK0-003
OIL SEAL (12X18X5) (ARAI)
$4.15 $2.85 1
Add To Cart
25 91207-MBN-671
OIL SEAL (35X45X6)
$5.67 $3.81 1
Add To Cart
26 91302-HA0-004
O-RING (6.8X1.Cool
$1.83 $1.42 2
Add To Cart
26 91301-473-003
O-RING (7X1.7)
$1.83 $1.42 2
Add To Cart
26 91306-PJ4-000
O-RING (6.8X1.9)
$1.83 $1.42 2
Add To Cart
27 91362-VD6-000
O-RING (P7)
$0.88 $0.59 1
Add To Cart
28 91370-461-000
O-RING (11.9X2.2)
$1.80 $1.32 2
Add To Cart
29 92900-06045-0B
BOLT, STUD (6X45)
$1.31 $0.96 1
Add To Cart
30 94109-12000
WASHER, DRAIN PLUG (12MM)
$0.58 $0.47 1
Add To Cart
31 94301-08140
PIN, DOWEL (8X14)
$1.13 $0.91 2
Add To Cart
32 99101-GHB-0800
JET, MAIN (#80)
$6.47 $4.34 1
Add To Cart
33 14514-115-300
COLLAR (6MM)
$2.00 $1.42 1
Add To Cart
34 91319-ME5-003
O-RING (5.5X1.4)
$1.35 $0.99 1
Add To Cart
Re: steering shake
Post  AURORA on Sun Jun 22, 2014 5:17 pm
xr honda to the max wrote:well l installed a new to me rim and tire assemby  no more steering shake and go top end , thought it would be faster then what it does , only 160 km ??????!!!!!!!!!!!!, my 500 xr goes closer but not as quick ???????????????!!
mike
What gears are you running?
Is the airbox side panel opened up?
Re: steering shake
Post  xr honda to the max on Sun Jun 22, 2014 6:00 pm
the motor is finished , both haves , con rod , balancer assembly done ,piston broke as well , will take a picture later for some laughs
thinking will buy another bike use this bike for parts ???!!
the air box wasn't cut out but uncorked at carb and correct items in carb
mike
xr honda to the max
xr honda to the max
Re: steering shake
Post  Mad Frosty on Mon Jun 23, 2014 9:12 pm
Big kuri had engine for sale , ask him if he still have it ?
Re: steering shake
Post  AURORA on Wed Jun 25, 2014 5:48 am
Re: steering shake
Post  AURORA on Wed Jun 25, 2014 5:50 am
Here you go:
http://cincinnati.craigslist.org/mcy/4535985225.html
CL >cincinnati >all for sale / wanted >motorcycles/scooters - by owner
contact x prohibited[?] Posted: 23 hours ago
01 honda xr650r - $1800 (newrichmond oh.)
This bike is the altamate woods weapon king of the trails if you want to have the fastest trail bike in the woods this is the bike for you its an 01 honda xr650r water cooled aluminum frame thumper 1,800 firm may trade for work van call or text
show contact info
do NOT contact me with unsolicited services or offers
post id: 4535985225 posted: 23 hours ago email to friend ♥ best of [?]
Avoid scams, deal locally Beware wiring (e.g. Western Union), cashier checks, money orders, shipping.
Re: steering shake
Post  Mauser on Wed Jun 25, 2014 7:42 am
Mad Frosty wrote:Big kuri had engine for sale , ask him if he still have it ?
I posted this reply in another topic...
Engine sold on ebay the other day....
http://www.ebay.co.uk/itm/2006-Honda-XR650R-Engine-Genuine-OE-complete-new-top-end-/221464047418?pt=UK_Motorcycle_Parts_13&hash=item3390492f3a
found anothe xr
Post  xr honda to the max on Wed Jun 25, 2014 1:39 pm
going to pick up another xr on the weekend , one year older then my blown up xr but has had resent top end work , New cylinder , piston , valves and cam chain , looks clean and all . will post pictures of it when l get her home
thats for the replys wish my 04 didn't blow the way it did , not sure what happened it was running quite well ??????????!!!!!!!!!!!just before it blew was throttling up from thrid gear to change to four and the tire locked up . Most of the parts were in a new belly pan that l just purchased and installed a couple days before the BIG RED PIG DIED. RIP will keep for parts bike now for the 03 l will have on the weekend
thanks mike
xr honda to the max
xr honda to the max
spare parts
Post  xr honda to the max on Wed Jun 25, 2014 2:03 pm
xr honda to the max
xr honda to the max
hard to see but crank through balancer through cases
Post  xr honda to the max on Wed Jun 25, 2014 2:04 pm
xr honda to the max
xr honda to the max
the 04 is going to the heeling department
Post  xr honda to the max on Wed Jun 25, 2014 2:13 pm
the 04 is going to the grave yard found a 03 , heres my 79 xr and my 81 xr500r they still burn tires , Will post my new bike when l get it later this week
RIP 2004 BIG RED PIG
my resent upgrade before she died , new clark tank , new seat , new to me front tire and rim no steering shake now BUT??!! , new brakes , sight tube for oil level , new belly pan ,many other little thing which l learn't on the forum
RIP my old 04 may you burn rear tires in your next life
thanks mike
xr honda to the max
xr honda to the max
Re: steering shake
Post  MA$TER_E on Wed Jun 25, 2014 2:24 pm
 Shocked  Oh the horror!
Not very often do you hear about a 650 coming undone. RIP piggy. Sorry for you luck. That sucks. I have some of my own bad luck but nothing that extravagant. Just know its rare for this to happen to a 650.
 cheers
MA$TER_E
MA$TER_E
Re: steering shake
Post  xr honda to the max on Wed Jun 25, 2014 2:54 pm
thanks for the reply Master E
l just confirmed my new purchase for 2003 big red pig, need to pick up, receved a picture to share
thanks mike
xr honda to the max
xr honda to the max
Re: steering shake
Post  Mauser on Wed Jun 25, 2014 3:47 pm
Who nicked the stand ?.... Bump
Re: steering shake
Post  MA$TER_E on Wed Jun 25, 2014 3:56 pm
Mauser wrote:Who nicked the stand ?.... Bump
LOL! didn't even notice that. Good eye Mauser. You'll want one of those stand things  nice
MA$TER_E
MA$TER_E
kick stand
Post  xr honda to the max on Wed Jun 25, 2014 9:47 pm
l seen that the stand was missing but l emailed the guy and he's from Quebec and doen't understand english , if he doen't have it will use the one from the 04 RIP. Had to use a interpurator for the deal
thanks mike
xr honda to the max
xr honda to the max
Re: steering shake
Post  Mad Frosty on Thu Jun 26, 2014 9:56 pm
He might takes frogs as a payment  StirPot
Re: steering shake
Post  BuRP on Fri Jun 27, 2014 8:55 am
Alors, une Frenchman hmm?
Make sure the gearbox does not have 5 reverse gears pls  BRP smile BRP smile BRP smile
Re: steering shake
