Carb rebuild kits. Any good?
Has anybody purchased one of the carb rebuild kits from ebay? They all seem to be between £20 and £30 and say they contain all necessary o rings and jets for complete rebuild. Seems very cheap to me!
Are they any good or is this a false economy and I should be going to my Honda dealer?
Re: Carb rebuild kits. Any good?
worth buing for the price but the needle and jets are useless , not b53 needle and the jets are wrog size .
I would stick with OEM items myself, still cheap even from Honda...and you will guarantee they fit and work 100%
Thanks guys. I think I'll stick to OEM, at least for the first time I take it apart. Are there any seals or O rings that should be changed as a matter of course very time you pull it apart, or should I just replace the ones that are obviously worn out?
Replace the lot , cheap enough to do , even if they look fine they can leak , consider the age of our bikes .
» Where to buy carb rebuild kit - UK ?
» 680 Kit & Overhaul
» Someone had to ... Sh*t Kits - let's share the insight!
» oversize bigbore kits
» Info Sort on Electric Start Conversion Kits
