Oil filled handle bars problems
Post  Mauser on Mon Nov 25, 2013 7:10 pm
Struggling to maintain decent flow through the bars ?, the warm up OK closest to the infeed connector but are less warm where the oil leaves the bars...struggling to work out whats wrong ?.
Also might need some high temp glue for the grips; I have the feeling the heat is softening the glue ?.
Re: Oil filled handle bars problems
Post  BuRP on Tue Nov 26, 2013 7:16 pm
It is the switches Mauser, they drain the temperature. As you (should!) know the coriolis effect in your part of the word converts heat to electricity, which on its turn is shed in light - at least if you've got the lights on, otherwise it will be heat however in other places than the bars.
Hence my question: are there any lights on Mauser?
Me thinks a fuse has blown though, which should be easy to find: look to tea spillings?
Post  Mauser on Tue Nov 26, 2013 7:29 pm
BuRP wrote:It is the switches Mauser, they drain the temperature. As you (should!) know the coriolis effect in your part of the word converts heat to electricity, which on its turn is shed in light - at least if you've got the lights on, otherwise it will be heat however in other places than the bars.
I don't really have switches Burpy...just a kill switch US spec and such listen up
As for lights only have the dipped plastic 35W main beam and 3.4W tail light so don't think they are messing up the oil flow ?....I have tried more tea but it doesn't help Neutral
Post  SkidMark on Tue Nov 26, 2013 7:30 pm
feed it in at both ends where you want the warmth and out in the centre... asking for it
Post  Mauser on Tue Nov 26, 2013 8:34 pm
SkidMark wrote:feed it in at both ends where you want the warmth and out in the centre... asking for it
I tried that but oil hoses stop the bars from turning ?
Post  SkidMark on Wed Nov 27, 2013 3:22 am
Make them longer...put some chips in the handlebars to absorb the oil and hold it in the ends....please you have an emergency snack if you get stuck out in the snow
Post  AURORA on Wed Nov 27, 2013 6:34 am
Oil? Bars? What are your talking about?Frustrated
Post  BuRP on Wed Nov 27, 2013 9:22 am
Aurora,
Mauser's NOT drinking tea for a change, he's clearly well oiled and talks/writes about anything - bar nothing Bump
Post  Mad Frosty on Wed Nov 27, 2013 10:53 pm
Is it the time of month again ,.... oh well .
razz
Post  BuRP on Thu Nov 28, 2013 12:58 pm
"Are you affected by the full Moon?"
"NooooOOOOOOoooooooooo......."
BRP smile
