Heidenau K60 sizing
Heidenau K60 sizing Empty Heidenau K60 sizing
Post  Zoro on Wed Dec 11, 2013 3:36 am
Is anybody using the K60 rear tyre on their piggy?
Would you know if the 140 rear fits the bike?
Zoro
Heidenau K60 sizing Empty Re: Heidenau K60 sizing
Post  Mad Frosty on Wed Dec 11, 2013 9:08 pm
Never used one , but 140 sounds like you might get little bit of chain rub  study
( i believe that it would fit but i might be wrong  scratch )
Post  Zoro on Sun Oct 11, 2015 12:34 pm
Just an FYI if anyone's looking at trying the K60, I can confirm that the 140 does fit.
I'm also trying out an HP4 Starcross on the front also, 90/100-21.
Haven't been for a spin yet but they do look good.
Zoro
Post  SkidMark on Sun Oct 11, 2015 8:03 pm
Zoro wrote:Just an FYI if anyone's looking at trying the K60, I can confirm that the 140 does fit.
good to know thanks, but I don't think I will use your supplier to get one.... scratch
Post  BuRP on Mon Oct 12, 2015 11:44 am
Dunno K60 but a 140 apparently fits.
(Disclaimer: blablabla... Bump )
Post  SkidMark on Mon Oct 12, 2015 4:35 pm
supplier took nearly two years to deliver.... dummy
Post  Zoro on Fri Oct 16, 2015 12:00 am
Lol...I originally had issues trying to get them so went with a couple of Mitas CO2's on the rear since then.
Last week I went to a local tyre shop and found an abundance of the K60's, he tells me the 140 will fit so went with that.
I must say it hangs on nicely both tar and dirt, doubt I'll go back to a knobby after using the Heidenau.
Props to the HP4 Starcross on the front also...
Zoro
Post  BuRP on Mon Oct 19, 2015 2:09 pm
Here's a tip, you can also step-up the width at the front a size.
In loose sand this will give you a lower flotation speed hence it 'climbs out' sooner, it is easier to ride.
This for those who dislike sand, if you like it no need to do this.
Post  wassie on Mon Oct 19, 2015 9:28 pm
What profile is the K60, 140?
wassie
wassie
Post  Zoro on Wed Oct 21, 2015 12:57 am
Wassie its 140/80-18
Zoro
Post  wassie on Wed Oct 21, 2015 2:59 am
Yeah, sorry about that, I knew they made a 120/90-18 and I thought the 140 may have been 90 and "thought that won't fit in a fit"
I was a little confused Smile
wassie
wassie
