east cape/ north island
just did a 800k weekend ride , even took some pictures, ill post them up soon, i found a backroad to get behind MT HIKURANGI, alledgedly the first place to see the sun
Re: east cape/ north island
thanks for sharing , nice ride , l like your black plastic on your XR , COOL , your head light looks nice did you need to change stator when installed
mike
mike
lighting
i did replace the stator, due to my wof requirements, i installed a electrosport twin 100watt output, one runs the headlight, the other runs a dc system that runs the brake lights, horn & indicators thru a small gel battery, im considering fitting some led running lights, 1x flood ,1 x spot to get even better night lights, [100wt halogen dip/100wt high beam at present]i had to fit a h/duty reg/rec to handle the output of the new stator, + i run an adjustable output trailtech ac reg for the headlights, the ascerbis h/light only came with 35wt bulbs, but seems happy running 100wt halogens, its nearly as good as a roadbike for lighting on high beam, but lacks a bit on dip
» new zealand- south island tour- 6000kms
» XR650R New Owner.. LET THE FUN BEGIN IN.. The North East
» 2nd North NM Jemez Ride - North end of Valles Caldera
» North NM DS Tour
» 01 BRP East TN
» North NM DS Tour
» 01 BRP East TN
