jerky pig
Page 2 of 2 Previous  1, 2
bad throttle resonse
Post  temporary kiwi on Tue Feb 18, 2014 12:40 am
have you checked the operation of the acl valve?
temporary kiwi
Re: jerky pig
Post  AURORA on Tue Feb 18, 2014 2:32 am
Yesterday, I posted this on the wrong post.
Air cutoff valve bad?
Are the jets and needle OEM Keihin or aftermarket? You must use OEM. Aftermarket manufacture's jets and needles can be all over the place in regard to true size due to crappy manufacturing tolerances. For example, even though it states it is a 68 the true sie could be a 60.
Some bikes like 70 pilot.
So you float is at the proper level?
Did you properly assembled Air cutoff valve bad?
Did you properly assemble the fuel/air screw?
Re: jerky pig
Post  MCVL on Tue Feb 18, 2014 10:32 am
What octane gasoline are you using?
Standing for 4 months the only thing that would realy change is the octane number decreasing
MCVL
Re: jerky pig
Post  BuRP on Tue Feb 18, 2014 12:26 pm
Mark,
on the LHS of the std carb is a lil' cover - behind which a small membrane lives.
The cover has a tiny bore in it - plug it with a drop of silicone or epoxy glue.
Let dry, reassemble & ride.... better now?
 BRP smile
Re: jerky pig
Post  SkidMark on Wed Feb 19, 2014 5:47 am
hmmmm - you think that will fix? I had the carb apart and checked all that was in good condition and working but decided not to do that mod becasue of mixed reviews online - will give it ago though if you think that will fix it.
Cheers
Re: jerky pig
Post  Mauser on Wed Feb 19, 2014 8:49 am
SkidMark wrote:hmmmm - you think that will fix?  I had the carb apart and checked all that was in good condition and working but decided not to do that mod becasue of mixed reviews online - will give it ago though if you think that will fix it.
Cheers
I agree I wouldn't bugger with my carb, try something less radical if you can maybe a rubber bung you could remove easily...pop it in try her out see what happens etc....
I heard another fix was to turn your carb right round and fit it backwards....not sure if it's a reliable source or not dummy
Re: jerky pig
Post  MCVL on Wed Feb 19, 2014 11:11 am
Mauser wrote:try something less radical
Maybe cheaper petrol?  BRP smile
It won't die becouse of a few dozens of miles, it didn't even when I had to fill it with 3/4 80-octane gasoline and 1/4 diesel mix in the middle of nowhere, just a little detonation if whacked the throttle to hard
MCVL
Re: jerky pig
Post  Mauser on Wed Feb 19, 2014 11:21 am
My comments were aimed at Mark's problems  BRP smile
Re: jerky pig
Post  MCVL on Wed Feb 19, 2014 11:26 am
Oh, smth about the chain slack problem, I didn't see it, sry Smile
P.S. I must have overworked a bit  crazy
MCVL
Re: jerky pig
Post  Mad Frosty on Thu Feb 20, 2014 12:05 am
Cheers
That is very dangerous mod mauser , it will add extra 20 hp to he bike and people cannot handle all that power - resulting in nasty accidents  listen up
Kepp your sticky fingers of my posts  dummy
Re: jerky pig
Post  BuRP on Thu Feb 20, 2014 11:07 am
TJE wrote: ... and clearly a virgin mechanic too!
Thomas, I'll be honest with you: I am ab-so-lu-te-ly fed up with my current job, and wish to relocate, do something else or whatever, but a change it must be!
Hence me taking interest in your line above, it tickled my fancy immeasurably!
Please help this old geezer to indulge a bit will ya?
Where do I go for training to become a virgin mechanic, what are the cost involved, and does one get to work on real virgins?
 BRP smile  Bump
Re: jerky pig
