Better Electrical Connectors
Post  Hodakaguy on Sat Jan 10, 2009 11:57 am
If you are installing wiring on your bike consider these connectors. They are made for RC aircraft and are extremely reliable, easy to connect and disconnect, can take high loads and they are very solid. WAY better than the cheap automotive style connectors that you buy at napa, shucks, ect. I just installed my 200W Ricky Stator and used these connectors to replace the ones that came on the stator assy, wires going to the lights, switches, ect ect. When you are in the middle of know where it pays to have solid electrical connections.
These are the connectors, available at any Hobby Shop.
Here they are out of the bag. They are solder on connections.
Here is a 14 guage wire soldered onto the male connector.
Add the heat shrink tubing to prevent shorts.
Connect the two halves and your done. Nice solid connection that you won't have to worry about. Very Happy
Here's a shot of my Ricky Stator harness with the new connectors installed on my BRP.
Hodakaguy
Hodakaguy
Re: Better Electrical Connectors
Post  Rd650 on Sat Jan 10, 2009 7:45 pm
Those are some clean looking connections.bow How much did they cost? A trip to the hobby shop will be coming soon.
Rd650
Post  Dave P on Sun Jan 11, 2009 4:55 am
Very nice! Your attention to detail is second to none.
The Dean's Ultra connectors are another super reliable R/C connector. They are a PIA to solder, though.
Dave P
XR650R Year : 2002, 2001
Post  Hodakaguy on Sun Jan 11, 2009 12:43 pm
Rd650 wrote:Those are some clean looking connections.bow How much did they cost? A trip to the hobby shop will be coming soon.
They are $2.99 per pack and you get three connections per pack. Not to bad when you compare them to the crapy automotive connectors at your local auto store.
Dave P wrote:Very nice! Your attention to detail is second to none.
Thanks, I really have nasty wiring. Yeah the Deans connectors are a great unit also, I run them on most of my lipo packs, they are a paint to solder though like you mentioned and a little bulky.
Hodakaguy
Hodakaguy
Connectors
Post  jm-2008 on Mon Jan 12, 2009 10:15 pm
For all low current applications (indicators, harness etc) OEM style bullet connectors can be obtained from Easter Beaver Trading at the following address -
http://easternbeaver.com/Main/Elec__Products/Connectors/Bullet_Connectors/body_bullet_connectors.html
These connectors require the correct roll over crimp tool as they anchor through the insulation as well as crimp over the wire strands (as per original style connectors).
Think they may be available from EB Trading as well.
jm-2008
Excellent Heads Up!
Post  Bump on Mon Feb 09, 2009 9:00 pm
I was considering this kit: http://www.trailtech.net/crimp_kit.html
But the stuff doesn't look that great. Plus I'd rather have solders than crimps.
THX
