Valve Check
Valve Check
Just done a valve check after owning the bike for nearly 5 years....they were spot on....
Re: Valve Check
Mad Frosty wrote:So the rumours about you are true then
Must be but really guys my cock isn't 12" more like 11" don't drop the soap in the shower Fruity
Re: Valve Check
You are the man , i cannot compete with that ,.....
mine is only 4" in diameter
Re: Valve Check
I've only done about a 1000 women in my life, so no, can't compete with 1200... life's a bits
Oh, and Maddy/Mauser, NO pictures please.....
» What is Check Valve for?
» Valve clearance on the pig
» Stuck Valve
» Drain oil for valve clearance?
» Stuck Valve
