Honda xr650r handle bar vibration
Post  Garyparnell on Mon Jun 23, 2014 3:57 pm
Hello does anyone know of some rubber mounted bar clamps to stop handle bar vibration, got standard clamps and bar at the moment
Thanks very much
Gary
Garyparnell
Garyparnell
Re: Honda xr650r handle bar vibration
Post  MA$TER_E on Tue Jun 24, 2014 5:05 pm
Garyparnell wrote:Hello does anyone know of some rubber mounted bar clamps to stop handle bar vibration, got standard clamps and bar at the moment
Thanks very much
Gary
One of the things I've heard is people remove the cross bar on the MX bars to let the bars flex a bit and that helps. But they bend easy when dropped. I run the USD conversion forks so they're kind of rubber mounted but after that ProTaper bars and ProTaper Pillow block grips. The grips cut down on vibration as well. If you're rich look into a set of fasst flexx bars. They're awesome. But spendy.
 cheers
MA$TER_E
MA$TER_E
Post  Zoro on Tue Jun 24, 2014 11:22 pm
I have Pro Taper bars on mine and use the black foam type grips, has nearly zero vibes at the bars with that setup
Zoro
Post  AURORA on Wed Jun 25, 2014 5:42 am
Have your crankshaft/rod/piston balanced! Bananatool
Post  Xrsaylor01 on Fri Jul 04, 2014 9:26 pm
I've heard of guys filling their bars with silicon or urethane, but I have no idea if that would soak up the vibrations or not. I did just buy a set of renthal fatbars without a cross bar and bought protaper bar adapters. I've not installed them yet but if they cut down on the vibrations I'll let you know.
Xrsaylor01
Xrsaylor01
