Flat Tyre Valve Stem
Post  Mauser on Wed Jul 16, 2014 2:27 pm
Never had that before...went for short ride yesterday and had a flat...by chance I was within 70 yards or my friends house, couldn't spot any nail so tried putting some more air in and found the valve stem had come away from the tube....lol....swapped tyres whilst I had the chance as rear was nearly worn out....all good now  BRP smile
Re: Flat Tyre Valve Stem
Post  ooeddym on Wed Jul 16, 2014 4:44 pm
Did the rim lock slip and let the tire spin on the rim and pull the stem out?
ooeddym
ooeddym
Post  Mauser on Wed Jul 16, 2014 5:56 pm
Don't think so...probably just old tube could have been 12 years old  Bump was only doing 10mph on tarmac Smile
Post  ooeddym on Wed Jul 16, 2014 6:55 pm
That is pretty old, I end up putting a huge nail through my tube before they get that old.  beat head
ooeddym
ooeddym
Post  Mad Frosty on Thu Jul 17, 2014 7:40 pm
Just old rubber , even tubes age and start cracking after some time , get a new one for the other wheel too just to be safe .
Post  ooeddym on Thu Jul 17, 2014 9:34 pm
Good call.
ooeddym
ooeddym
Post  Mauser on Thu Jul 17, 2014 9:37 pm
No chance old rubber rocks....most of the time  razz
Post  BuRP on Fri Jul 18, 2014 9:33 am
New rubber for me every time!  razz
Post  forestgrump on Sun Sep 25, 2016 1:29 am
Mauser wrote:Never had that before...went for short ride yesterday and had a flat...by chance I was within 70 yards or my friends house, couldn't spot any nail so tried putting some more air in and found the valve stem had come away from the tube....lol....swapped tyres whilst I had the chance as rear was nearly worn out....all good now  BRP smile
Do you tighten down the nut on your tire valve. If you do and your tire spins on the rim or you get a flat, it will pull the tire valve out of the tube. I f you run the nut to the top against the bottom cap it allows the valve core to move lessening the chance of ripping it out of the tube. Not that any XRR has enough torque to spin the rear tire or tyre. lol
forestgrump
forestgrump
Post  Mauser on Sun Sep 25, 2016 9:33 am
Bit late with advice.....2 years ago lol..... Frustrated
Post  forestgrump on Mon Sep 26, 2016 10:38 pm
Mauser wrote:Bit late with advice.....2 years ago lol..... Frustrated
Better late than never? Forest
forestgrump
forestgrump
