2001 hondaxr650r Baja designs light kit
Post  Sidm4193 on Fri Aug 01, 2014 2:16 am
Well to make a long story short I purchased a 2001 honda xr650r a few days ago from someone who told me a great lie that the lights don't work cause I need a new battery. Well after searching for this battery (cause I'm new to the whole dual sport thing) I found it about ten batteries wrapped in some black tape.
Turns out there's more wrong then just that battery, this guy has grounds hot and it's the worse nightmare I've ever had. I can't even sleep right knowing that this spiderweb is behind my headlight right now. I'm gonna post pics as soon as I get in my garage any guidance or experience with this same problem please feel free
Sidm4193
Sidm4193
Re: 2001 hondaxr650r Baja designs light kit
Post  ooeddym on Fri Aug 01, 2014 5:46 am
Master E completely rewired his bike because of the rats nest behind the number plate. for the most part the electrical is relatively simple but all the wire in the baja kit makes it look like a complete mess. I bet he might even have some great pictures and wire diagrams he can post.
ooeddym
ooeddym
Post  Mauser on Fri Aug 01, 2014 8:42 am
Come on the bike only a hand full of wires to start with, if your that worried just pull everything off and stick a stock loom back on they are dirt cheap over the pond !!!
If you want more than stock I can never understand why people don't obtain a UK/EU stock loom and stator etc and just swap them over...no need for a battery  listen up
Post  Sidm4193 on Fri Aug 01, 2014 4:09 pm
The harness for the Baja kit is the rats nest. I've even figured out this guys mess and had the lights and all turn signals working but once the bike got shut off. Everything quit working when I started it back up. I'm not an expert electrician but I know enough to know whoever wired this did not know what they was doing if anyone has the 2001 honda xr650r stock wiring diagram that would be awesome. I think I'm just gonna start off from scratch. And ooeddym can you shoot me to this master e your talking about
Sidm4193
Sidm4193
Post  Mauser on Fri Aug 01, 2014 4:56 pm
Sidm4193 wrote:if anyone has the 2001 honda xr650r stock wiring diagram that would be awesome.
UK Spec or US spec...BIG difference  BRP smile
Post  Sidm4193 on Fri Aug 01, 2014 5:39 pm
Sorry.. US
Sidm4193
Sidm4193
Post  Mauser on Fri Aug 01, 2014 7:09 pm
