another standard carb issue
Page 4 of 4 Previous  1, 2, 3, 4
Re: another standard carb issue
Post  kirky on Wed Sep 03, 2014 1:04 pm
Zoro wrote:What about valve adjustment, where is that at the moment?
You'd be surprised how much better/ smoother these things run with the valves adjusted correctly.
Be sure to disconnect the decomp cable from the lever prior to adjusting them and triple check the gaps by turning the engine 720 between checks.
Hi Zoro i just set the valves to the standard specs and checked them last week so the valves should be good.
altho i did not disconnect the decomp cable, i didnt think that would be necessary for checking/adjusting the valves?
i know its a long shot but would there be any way to tell if the crank has been changed to a stage1/2? as i know the valve specs would be different if that had been done by a previous owner shrug
kirky
Post  Zoro on Wed Sep 03, 2014 2:25 pm
A good indication of cam change would be the lack of decompressor. You might still have the lever but does it actually work?
Mine runs great on the settings I gave you, runs fine with the larger MJ's too. I wonder if the ACV bladder is leaking air as in it has a hole in it? The mod doesn't account for that, you're probably better off just blocking the vacuum port and eliminating a leak path. One other thing I do to mine is fill the gap around the mixture screw with grease to prevent a possible vacuum leak.
Does sound electrical though, you're not on the limiter are you??lol
Let's assume the carb is fine, its breaking down at rpm. Coil/ ht lead or plug/plug cap?
Could be something stupid like your kill switch playing havoc at high rpm/ vibes or wiring harness issues?
A connector not fully seated or dry contacts etc..
Swap plugs/ correct rating??
Just thinking out loud here and throwing ideas into the wind.
I would at least put the 68S back in, it should run fine on any mj between 170-180 for this exercise. At least put it back to your best combo.
There's other issues at play here me thinks...
Zoro
Post  kirky on Wed Sep 03, 2014 6:37 pm
Zoro wrote:A good indication of cam change would be the lack of decompressor. You might still have the lever but does it actually work?
thanks for the information Zoro, i do still have the decompression lever and yes it still works so would it be a safe bet to say the crank is the standard one?
also does the decomp have to be disabled to do the valves on these?
i have used the bike for maybe 10-15 miles today an i can safely say its not on the limiter, even if i pull out of a junction and just pin the throttle it loses all power until i roll off the throttle.
i will try and pick up some fuel resistant silicon to seal the vacuum hole but i did give the ACV a good inspection and it looked new, it was a tight snug fit with no holes.
did you fill it all the way to the seal around the mixture screw with grease or just a thin layer?
I am starting to think its not the carb after all this since the constant loss of power on full throttle has calmed down now and then but never gone away like others have had happen after a carb service but i wouldn't know were to begin with the electrics haha
kirky
Post  Mad Frosty on Wed Sep 03, 2014 7:49 pm
It will be for the best to install my carburettor in your bike to see how it runs then , if it still runs bad we can rule the carburettor out , this is the only way , you lucky that i only live few miles away rider rider
Post  kirky on Wed Sep 03, 2014 7:59 pm
Mad Frosty wrote:It will be for the best to install my carburettor in your bike to see how it runs then , if it still runs bad we can rule the carburettor out , this is the only way , you lucky that i only live few miles away rider rider
i think you might be right frosty.
kirky
Post  Mad Frosty on Wed Sep 03, 2014 8:09 pm
Cheer up man , we will sort it nice
Post  kirky on Wed Sep 03, 2014 9:56 pm
Mad Frosty wrote:Cheer up man , we will sort it nice
oh i hope so frosty, my other bikes now off the road for a few month since i have been sinking all my spare cash into this.
At least it looks like i will have lots of carb spares BRP smile
kirky
Post  Zoro on Thu Sep 04, 2014 1:53 am
Kirky, take Frosty's carb and give it a go, let us know.
Zoro
Post  beaver350 on Thu Sep 04, 2014 6:37 am
Zoro wrote:Kirky, take Frosty's carb and give it a go, let us know.
This is going to be the most intensely watched carby swap on planet earth, may the force be with you listen up Twisted Evil 2 thumbs
beaver350
Post  Zoro on Thu Sep 04, 2014 7:56 am
I also like to intensely watch Beavers too, but that's a whole nuther forum... banana
Zoro
Post  kirky on Thu Sep 04, 2014 8:04 am
HA i just hope it works so i know what the problem is and as for the beavers it depends what type of beavers you like to watch thats funny
kirky
Post  Mad Frosty on Thu Sep 04, 2014 7:04 pm
I have a day off tomorow , need to get to Darlington in the morning , should be back just before 12 oo , if you wanna come here and so we can fix the bike , i will be working on saturday Crying or Very sad
Double post , it must be the beaver effect lol!
Post  kirky on Thu Sep 04, 2014 9:27 pm
Mad Frosty wrote:I have a day off tomorow  , need to get to Darlington in the morning , should be back just before 12 oo , if you wanna come here and so we can fix the bike , i will be working on saturday Crying or Very sad
hey frosty that sounds great, i will fetch all the spares i have as well and tools BRP smile
kirky
Post  Mad Frosty on Thu Sep 04, 2014 9:34 pm
What's wrong with my tools scratch
Post  kirky on Thu Sep 04, 2014 9:40 pm
Mad Frosty wrote:What's wrong with my tools scratch
Not greasy enough razz
kirky
Post  BuRP on Fri Sep 05, 2014 12:41 pm
Mad Frosty wrote:What's wrong with my tool scratch
Well Frosty, you seem to be into beavers?
Ask them!
Post  Mad Frosty on Fri Sep 05, 2014 1:04 pm
The beavers have told me last night that there is no way the whole tool will fit in , so yes apparently i need a smaller one shrug
Post  kirky on Fri Sep 05, 2014 8:40 pm
HUGE thank you to frosty for his help today, it looks like its my arch enemy and that horrible witch craft known as electricity to blame for my running woes Frustrated
we tried a few idea's with the carbs, swapped mine for his but still no luck until we swapped the cdi and hey presto....Bananatool
now i just need to find a replacement cdi affraid
oh and swapping from your cdi back to mine for the trip home seems to of affected my vector speedo slightly, its gone from Fahrenheit to Celsius, mph to kph and it said i was doing 385kph on the way home lol!
kirky
Post  beaver350 on Fri Sep 05, 2014 9:08 pm
At least you know you carb is nice and clean inside, beavers are smiling all over the world banana 2 thumbs cheers
beaver350
Post  Mad Frosty on Fri Sep 05, 2014 9:22 pm
Yes new CDI  needed , i would also recomend new AC regulator as i think your voltage its little bit higher than it should be ,
http://www.bajadesigns.com/ProductDetail?ItemNumber=122002
this is a heavy duty one  that will last forever , or try ebay for a nice OEM one .
New fuel mixture screw , clean your air  filter, clean inside the airbox + install the backfire screen  asking for it  , check the oil level  ,...
and start using both wheels  Bump
Post  kirky on Fri Sep 05, 2014 9:56 pm
Mad Frosty wrote:Yes new CDI  needed , i would also recomend new AC regulator as i think your voltage its little bit higher than it should be ,
airbox and backfire screen will be hopefully sorted tomorrow if i am out of the doghouse Embarassed
we must of made a better connection on the cdi when we put it back on as the bike performed good on the way home, it was a fun ride back in the dark(minus terrible headlight)
still i bet i am the first person to have 385kph and there xr speedo, satnav wasn't so optimistic though, that said something else Wink
i was just trying to preserve the front tyre rider
kirky
Post  kirky on Sat Sep 06, 2014 2:57 pm
damn it, looks like i got outbid on the only cdi on ebay beat head
anybody got any idea's were i might be able to grab one?
kirky
Post  Mad Frosty on Sun Sep 07, 2014 12:13 pm
The XR400 CDI will work as well 2640 and 2740 if i remember it correctly , 2640 supouse to be better .
Post  Mad Frosty on Sun Sep 07, 2014 12:24 pm
Post  kirky on Tue Sep 16, 2014 8:37 pm
I would just like to say thank you to everybody who has helped me out with this problem, it looks like it was not the carb(even though it needed re-jetting/servicing) or the cdi(even with a dead pin).
after all the money and time i have put into solving this problem and with the help of Frosty 2 thumbs it turns out it was the trail tech vapor speedo and they way the previous owner had wired it in doh
been out for a few blasts about on it since i unplugged the trail tech vapor and the problems have vanished, now i just need some front & rear wheel spacers for the standard wheels so i can get the knobbly's on rider
kirky
