cfr 450 plastics fit on a xr650r?
Post  welovesocalbuzz.sanderson on Tue Sep 30, 2014 3:25 am
Has anyone put cfr 450 plastics on the brp. Will the crf460 rims fit on the pig also?.thanks
XR650R Year : 2006
Re: cfr 450 plastics fit on a xr650r?
Post  ooeddym on Tue Sep 30, 2014 5:18 am
CRF wheels will fit the XR. You will need spacers to adapt the small xr axles to the big CRF bearings. This place has exactly what you you need, he is very helpful and knowledgeable regarding wheels. I think the spacers were $35 a set.
http://www.motoxindustries.com/
ooeddym
Post  welovesocalbuzz.sanderson on Tue Sep 30, 2014 5:40 am
Thanks ooeddym
XR650R Year : 2006
Post  xrmanu on Wed Nov 19, 2014 5:50 pm
I have Crf plastic modded to fit my 680R. Cool
xrmanu
XR650R Year : '00
Post  ooeddym on Wed Nov 19, 2014 8:06 pm
Did you have to cut the 650 inner fender to keep the stock air box and rear mud flap?
ooeddym
Post  xrmanu on Wed Nov 19, 2014 8:16 pm
Yep ...and you find some info about the fender swap here:
http://supermotojunkie.com/showthread.php?130132-Clean-White-XR650r-SM-lots-of-tricky-bits
http://www.xr-italia.com/forumxr/index.php?topic=34471.0
You have to work and cut very carefully to have a good/tasteful result. I have done it 15 to 20 times and still every time it's precision work.
xrmanu
XR650R Year : '00
Post  dweller on Sat Nov 22, 2014 8:05 pm
Stock plastic looks better...
dweller
