Rear Brake Clevis Split Pins x 2 ?
Rear Brake Clevis Split Pins x 2 ? Empty Rear Brake Clevis Split Pins x 2 ?
Post  Mauser on Thu Oct 02, 2014 11:02 am
I can understand the split pin holding the clevis pin in....otherwise it will fall out lol, but why does the master cylinder rod have a pin in it ?.....could never see this coming loose as it has a locknut ?..... Frustrated mine no longer has this pin....never noticed it and as I unscrewed the clevis it sort of got chopped through lol.
Rear Brake Clevis Split Pins x 2 ? Empty Re: Rear Brake Clevis Split Pins x 2 ?
Post  ooeddym on Thu Oct 02, 2014 9:17 pm
uuuu? picture?
ooeddym
ooeddym
Post  Mauser on Thu Oct 02, 2014 11:04 pm
ooeddym wrote:uuuu? picture?
Item 23....
Rear Brake Clevis Split Pins x 2 ? RearBrake+MasterCylinder
Post  ooeddym on Thu Oct 02, 2014 11:18 pm
Ahh, very interesting indeed. Who can understand the engineering mind.
ooeddym
ooeddym
Post  BuRP on Fri Oct 03, 2014 11:42 am
An additional weight of 0,000001 stone (= 2 grams! BRP smile ) ensures that one cannot loose the locknut neither nut IF it comes loose - and it will with some owners, if not sooner than later.
Leave it in Maus', it's an OEM part after all, and yours is bogstandard I believe ...... minus some anti-smog & choking rubbish which is a good thing! Bump
Post  Mad Frosty on Fri Oct 03, 2014 7:03 pm
Cheap to sort out , so i cant see reason why not fix it BRP smile
Post  Mauser on Fri Oct 03, 2014 8:53 pm
Have you ever tried fitting that pin ?....I didn't notice it was there and managed to undo the clevis....only to find the remains of the pin loooooooooooooooooooool it won't be going back in stock or not BRP smile Anyway my bikes to clean for it to fall out WD40 means no failures on my bikes lol.
