Jet needle loose in the throttle valve?
Hello. Have a 2002 xr and rebuilding the carb for the first time.
Putting it back together, realized the jet needle just kind of sits there with a fair amount of play in the throttle valve.
Is this normal?
Is this normal?
Re: Jet needle loose in the throttle valve?
I think it floats on the needle seat...supposed to be like that...you wouldn't want it slightly out of line and wearing in the jet seat ?
» Loose Headstock?
» Exhaust working itself loose
» Kick Start Lever Came loose and lost it on my weekend ride
» Valve clearance on the pig
» Valve Check
» Valve Check
