Piston oil spray jet
Piston oil spray jet Empty Piston oil spray jet
Post  Chris_w_65 on Sun Nov 23, 2014 11:07 pm
I put new orings on the oil spray jet but it seems to slip out easier that what it goes in. I can imagine if it pops out while riding it will be a serious problem.
Anyone had experience with these?
Piston oil spray jet Oil_sp10
Chris_w_65
Chris_w_65
Piston oil spray jet Empty Re: Piston oil spray jet
Post  Mad Frosty on Mon Nov 24, 2014 12:04 am
Is that just pushed in without any securing device ?
Post  JRZ7285 on Mon Nov 24, 2014 2:38 am
I checked schematic don't see any clip that holds it in place! It must be held in by the O-rings but don't take my word for it, not sure unless I had it in my hand! maybe someone on here has dealt with these before who will chime in! shrug
here's the schematic if you want to check it out!
http://www.servicehonda.com/parts/lookup#/Honda/XR650R_A_(02)_MOTORCYCLE%2c_JPN%2c_VIN%23_JH2RE010-2K300001_TO_JH2RE010-2K399999/CRANKCASE/XR650R-02-JPN-A/2Y14MBNYMBN4E1200DD
JRZ7285
JRZ7285
Post  Mad Frosty on Mon Nov 24, 2014 8:44 pm
The oil pressure might not be enough to push it out then i guess scratch
Post  BuRP on Wed Nov 26, 2014 1:44 pm
If there's oilpressure behind it something must hold it in place, mere o-rings won't do that.
Check the barrel's bottom, does this have something sitting on / holding this jet?
Post  jayjay on Thu Nov 27, 2014 2:28 am
I have replaced the o rings on the oil jet and you can not push it in with your fingers and if you do it will fall out and do bad things. I oiled the o rings and  used a half inch piece of wooden dowel and had to give it a good quick rapp with a small hammer. You will feel it when it pops into place. 2000 miles later and all is well.
jayjay
jayjay
XR650R Year : 2006
Post  Chris_w_65 on Fri Nov 28, 2014 2:15 pm
jayjay wrote:I have replaced the o rings on the oil jet and you can not push it in with your fingers and if you do it will fall out and do bad things. I oiled the o rings and  used a half inch piece of wooden dowel and had to give it a good quick rapp with a small hammer. You will feel it when it pops into place. 2000 miles later and all is well.
Going to try that quick. I am using the correct Honda o-rings and have confirmed the measurements - the top ring OD with o-ring on the jet is 11.9 and the hole (measured crudely with the back end of a 12mm drill is slightly over 12mm) - Now there is a problem already
Bottom one OD is 10.1 and the hole measured with same crude method is just over 10mm
I see Honda has superseded the lower o-ring twice already to fatter ones. I am going to supersede the top one myself - The top one is 8.5 ID and 1.7 thick (bottom after superseding is 6.8x1.9 thick)
Size of grooves on jet
Top = 9.03x2.3
Bottom = 7.09x 2.1
Will go try the whack method quick to see if it seats better
EDIT - probably not worth checking the whack method - with the o-rings on it seated all the way in and I just checked with no o-rings and it also goes all the way in but apart from the o-rings there would be nothing else to hold it or seat it better
Chris_w_65
Chris_w_65
Post  jayjay on Sat Nov 29, 2014 1:05 am
There is nothing else that holds the oil jet in place except the o rings. I could not even come close to seating the oil jet in all the way with the 2 new o rings by using my fingers. Only way was tapping the oil jet.
jayjay
jayjay
XR650R Year : 2006
Post  Chris_w_65 on Sat Nov 29, 2014 3:16 pm
jayjay wrote:There is nothing else that holds the oil jet in place except the o rings. I could not even come close to seating the oil jet in all the way with the 2 new o rings by using my fingers. Only way was tapping the oil jet.
On closer inspection I see the oil does not come in through the jet at the bottom and out the top - There are holes almost like an emulsion jet between the 2 o-rings - The oil comes in between the 2 o-rings then some sprays up to the piston and I assume down some to a bearing.
Perhaps the difference is that I oiled the o-rings and turned it as I pressed it down and that is why it did not need knocking in to seat.
Just for piece of mind I got slightly different o-rings and they now have an OD about ,2 of a mm bigger than stock when fitted than the originals - It is a much tighter fit and in view of the fact I now know the oil pressure is not coming from the bottom I am sure it will not pop out.
Chris_w_65
Chris_w_65
Post  Andrea XR-Italia.com on Mon Dec 01, 2014 7:17 am
If I'm not wrong that spray is keeped in place by the bottom of cylinder..
http://www.xr-italia.com
Post  Chris_w_65 on Mon Dec 01, 2014 7:26 am
Andrea XR-Italia.com wrote:If I'm not wrong that spray is keeped in place by the bottom of cylinder..
Thanks, good point. I did not think to check for that
Piston oil spray jet 20141110
Chris_w_65
Chris_w_65
Post  BuRP on Tue Dec 02, 2014 11:14 am
BuRP wrote:Check the barrel's bottom, does this have something sitting on / holding this jet?
Ahem....
I told you's so!
Erm, no, wait, I asked you's so BRP smile
Chris jou bliks..., pls check and let us know? Bump
(Chris has got his entire engine apart at the mo, he should be able to check quickly)
Post  Chris_w_65 on Tue Dec 02, 2014 11:20 am
Ahem....
I told you's so!
Please see photo above - Already got cam in now - Too late to check but if anyone has a loose right side casing and a barrel they can let us know
Chris_w_65
Chris_w_65
Post  Chris_w_65 on Tue Dec 02, 2014 11:24 am
Ahem....
I told you's so!
For some reason email notifications were not coming through so I missed your post. I would have checked at the time if I had seen it.
Chris_w_65
Chris_w_65
Post  jayjay on Thu Dec 04, 2014 1:49 am
You know I never thought of the bottom of the cylinder holding the oil jet in place. Makes sense if it does.
jayjay
jayjay
XR650R Year : 2006
Post  Chris_w_65 on Thu Dec 04, 2014 2:55 am
jayjay wrote:You know I never thought of the bottom of the cylinder holding the oil jet in place. Makes sense if it does.
Sure does and would be a "nice to know"
Anyway, if you guys want the size o-rings I used for a snugger fit I can measure them up.
Chris_w_65
Chris_w_65
Post  BuRP on Thu Dec 04, 2014 2:10 pm
Mind, if this oiljet is fed by holes in the side (ie radial holes) and only has a hole on one end (ie a single axial hole, the oil-jet) then it needs very little to hold it in place, the dual O-rings will suffice.
The OP might know is this is the case?
Post  Chris_w_65 on Thu Dec 04, 2014 2:14 pm
BuRP wrote:Mind, if this oiljet is fed by holes in the side (ie radial holes) and only has a hole on one end (ie a single axial hole, the oil-jet) then it needs very little to hold it in place, the dual O-rings will suffice.
It sprays up and down - both ends
Chris_w_65
Chris_w_65
Post  BuRP on Thu Dec 04, 2014 2:23 pm
Then, if the bottom of the hole is blind it needs something to secure it.
If it sprays on the bearings or something at the bottom then not, it'll be sortof balanced.
And Chris, where's me tools bru?
Got weeks of spannering ahead of me, it's high time for that braai you were going to throw - I'll bring some wine, no sweat. You got the number..... asking for it
Post  Chris_w_65 on Thu Dec 04, 2014 2:39 pm
BuRP wrote:Then, if the bottom of the hole is blind it needs something to secure it.
It sprays down but not sure if to the right side balancer bearing or off to somewhere else
Will make a plan with that braai and my engine will be 100% assembled this weekend.
And hopefully some day before I die XR650.CO.UK will sell me the parts I need to complete the project - I am just trying to get them to deliver to an address in the UK and I have had at least 5 family/friends over there recently that would have brought the parts and my swingarm tools over beat head beat head beat head
Chris_w_65
Chris_w_65
