Replacing vented side cover with non vented side cover.
Post  MCM on Thu Apr 30, 2015 4:24 pm
My new to me 01 XRR runs really strong & starts easy.
Its pretty much stock, Its uncorked with a header & exhaust, K&N filter & side cover vents. Per the previous owner its stock carb is jetted a tiny bit on the rich side. Am replacing the scratched up vented side cover with the stock OEM non vented cover. Does the vented cover have much effect on jetting? I wouldn't think so but wanted to ask.
MCM
MCM
Re: Replacing vented side cover with non vented side cover.
Post  Mauser on Thu Apr 30, 2015 4:43 pm
Just drop in a stock jet and your sorted.... Bump
Post  MCM on Thu Apr 30, 2015 5:09 pm
Am new to these bikes, but I would think uncorked with full exhaust has a larger effect on jetting than a few holes in the airbox cover? Not sure stock jetting as you mentioned is the ticket uncorked with a pipe.
Also, Calif. stock jetting is probably different than the rest of the world. LOL LOL
Have only had the bike a week. The prev owner said it has a 180 main jet.
Am at sea level and it seems to run really well as is. Just not sure the vent holes really effect this?
MCM
MCM
Post  SkidMark on Thu Apr 30, 2015 8:11 pm
yes you will probably have to rejet. Have a search around there are charts that will give you ballpark jets for different altitudes and setups (ie opened side panels, different exhaust....).
Best way is to do runs and a plug chop - plus you will find out your bikes top speed during the full throttle run... nice
Post  Mad Frosty on Thu Apr 30, 2015 8:42 pm
Yes the side panel does affect the fuelling , so you will need to rejet , it will run even richer so you need to go with smaller jets , two sizes down on the main jet i am guessing .
Post  MCM on Thu Apr 30, 2015 10:33 pm
That's what I need to know.
Thanks!
MCM
MCM
Post  BuRP on Tue May 05, 2015 12:05 pm
Fist off, ditch that K&N filter, and do it quick too!
It's a cotton gauze type and they let fine dust through - good enough for the road, engine-ruining for offroad.
Your 180 is already too big I'd guess, 175 would be the ticket if not a 170.
Drop in a std (closed) sidepanel and you'd end up with a 165 - and yes, that's with an 'open' silencer.
Play around with a 165 & 170 and take it from there, jets are cheap enough.
Post  MCM on Tue May 05, 2015 4:22 pm
Honda XR650R (Honda Tech Bulletin)
https://www.4strokes.com/tech/honda/650rmods.asp
Part Description
Competition Spark Arrestor
Carburetor Insulator
Main Jet (#175)
Jet Needle
Jet Needle Clip Position
Airbox Inlet Duct Caps
(Air intake restrictors)
Honda P/N
18317-MBN-640
16211-MBN-640
99101-357-1750
16012-MBN-641
N/A
N/A
Instructions
Replace existing spark arrestor with this part.
Replace existing carb insulator with this part.
Replace existing main jet with this part.
Replace existing jet needle with this part.
Set jet needle in center (3rd) position.
Remove caps per this diagram.
MCM
MCM
Post  BuRP on Wed May 06, 2015 10:01 am
As I said, play around with a 165 & 170 and take it from there, you just might surprise yourself Cool
Post  Zoro on Wed May 06, 2015 11:32 am
I have tried the 175, 165 and 160.
Found the 165 to be very close for my environment (sea level and 30-38 degrees C). The 175 left the tail light and number plate black after a decent highway ride.
Zoro
