Mikuni TM 40
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Mikuni TM 40
Mad Frosty wrote:i dont know yet what the perfect setting is but i am at 1,8mm up from the factory setting
I assume you mean the float level is +- 21mm?
Yes it arrived today so I though fork it I''l play with it instead of doing house work...
Re: Mikuni TM 40
Last edited by appleseed on Sat May 23, 2015 11:48 am; edited 1 time in total (Reason for editing : found the answer by thinking about it :|)
Re: Mikuni TM 40
deleted a dumb question...
Last edited by appleseed on Sat May 23, 2015 2:59 pm; edited 1 time in total (Reason for editing : deleted a dumb question...)
Re: Mikuni TM 40
The factory setting is 19 mm , measure that before you change it , so you will learn the correct way of measuring , it will come set at 19 mm , i have found that in order to get the propper measurement the tilt of the carb had to be bit bigger than 20 degrees , it needs to just touch the pin without pushing it in , not easy but important otherwise you will mess it up .
Cables
I presume you have cables by now, i got mine made up by VenHill Engineering in Dorking.
Re: Mikuni TM 40
Mad Frosty wrote:
I really needed this picture 2 months ago when i needed to put it back to stock and couldn't work out how to measure the 19mm. I got fuel out of all the overflows at one point.
Re: Mikuni TM 40
Yes i already have new cables, but will keep VenHill Engineering in mind for the next time...
Also you win the award from most overflows overflowed
Re: Mikuni TM 40
The3 TM40 does not need altering the floatlevel to prevent peeing when leaning over on the sidestand, only the std carb needs it sometimes.
Fwiw.
MotionPro makes cables Appletjie, got mine from them and they're good. Measure accurately though (I guessed mine, fine though), always helps to get what you need.
Fwiw.
Page 2 of 2 • 1, 2
» Mikuni TM 40, TM 42 and TM 45
» Mikuni Tm 40 carb
» Mikuni TM40
» Mikuni TM 40 pumper / Edelbrock
» Mikuni Tm 40 carb
» Mikuni TM40
Page 2 of 2
