clutch help needed
clutch help needed
Post  torqueandpower on Sun Aug 16, 2015 9:37 pm
Hi, im going to check my clutch is good
can i take clutch cover off without draining oil?
Or drain just the sump plug?
and will it be easy to see if my clutch bush is crap?
thanks for any help
torqueandpower
Re: clutch help needed
Post  Mauser on Sun Aug 16, 2015 10:07 pm
Full of oil...lean bike over or drain down....don't think you can see clutch bush 2002 bike should be fine.
Post  Hew on Sun Aug 16, 2015 10:16 pm
If you lay the bike on its side you should be fine.
Make sure that you reseal the casing before lifting the bike back up for any reason.
Hew
Post  torqueandpower on Sun Aug 16, 2015 10:23 pm
Nice one thanks for helping
torqueandpower
Post  BuRP on Mon Aug 17, 2015 1:37 pm
Darnit Hew,
who gave you the right to be clever hmm? BRP smile Bump
He's quite right though, dump it on its side, a mattress will help wonders here.
But why?
Drain the oil and put fresh in, it's only 2 litres, and the Piggie will love you for it. Oh, new filter too eh, and when the clutch is out do not forget to check the mesh/sieve behind it!
Post  BuRP on Mon Aug 17, 2015 1:40 pm
On your clutch bush, you know this likely (for your year-model) has to be upgraded, a different part than what was installed?
Probably... and you can see/recognize the 'new/improved' part by spotting some grooves/machined indentations (my English may be lacking here?) in the bush's inner surface / the actual bearing surface. If this surface is smooth then it's the old/wrong one, replace it.
