XR650R Loud knocking after exit the HWY
Page 4 of 5 Previous  1, 2, 3, 4, 5  Next
Re: XR650R Loud knocking after exit the HWY
Post  JRZ7285 on Sat Nov 07, 2015 12:46 pm
wassie wrote:Nothing to worry about, that's normal on any casting on your bike or any other bike.
Wassie's right! there just casting marks, very normal i have some on mine and some of my buds have them on there crf's and xr600's no worries! build on my friend Bananatool
JRZ7285
Post  Mauser on Sat Nov 07, 2015 1:42 pm
Thought you were on about the welded bit ?....looks to me like a repair ?
Post  BuRP on Mon Nov 09, 2015 11:44 am
That mark's no worry, you better pay attention to the oilpump's housing - does it measure correct (according to the workshop manual)? Looks worn if not machined, better make sure it's all (rotors too) good still.
compression loss
Post  temporary kiwi on Thu Nov 12, 2015 10:08 pm
just noticed the nice job your machine shop did on the combustion chamber, however that also means you could have lowered the comp ratio, thats if your using the std piston, a hi-comp piston will rectify that and give you more grunt
temporary kiwi
XR650R Year : 02
Post  bikerman on Sat Sep 10, 2016 2:31 am
Thanks for the comments, sorry I was lazy this winter and I didn't work on my bike so I started to work back on her late this year. I got the engine all back together, I did use the Stock piston since I wasn't sure about the HC one, well I will see how it feels with it first, if I have to change it later on I can do that anytime. Something to do to my piggy LOL! The only thing I am concern on my rebuilt is I have an extra washer laying on my working bench which I can not remember where this could be left behind! I check carefull all the manuals picture but I can not see I missed it! I hope it will not make a big deal out of it!.
bikerman
bikerman
Post  bikerman on Sat Sep 10, 2016 4:22 am
Hey Guys, Any tip to start the engine after a rebuilt?
bikerman
bikerman
Post  Mauser on Sat Sep 10, 2016 8:58 am
I would prime the oil filter and kick her slowly over by hand with the de-compressor in to make sure oil is everywhere, I think some even crack the oil hoses to make sure there is no air trapped.
Post  bikerman on Tue Sep 13, 2016 4:07 am
Here is a short video after my rebuilt on the first starter, eventhough I got 2 bolts extra and a thrustwasher left over
bikerman
bikerman
Post  bikerman on Tue Sep 13, 2016 4:09 am
bikerman
bikerman
Post  bikerman on Tue Sep 13, 2016 2:52 pm
Try this link the other one doesn't load
http://illiweb.com/fa/pbucket.gif
bikerman
bikerman
Post  bikerman on Tue Sep 13, 2016 5:31 pm
bikerman
bikerman
Post  bikerman on Tue Sep 13, 2016 5:33 pm
Just installed my rear fender tool bag, I like it! Reminds me of my old XR500 1979!
bikerman
bikerman
Post  bikerman on Tue Sep 20, 2016 2:51 pm
Here is my XR on the road with an LED aditional fog lights! Running great and powerfull again! Just change the oil and filter after 1 week break in, it came out black from friction and the new Aluminum parts
bikerman
bikerman
Post  bikerman on Thu Sep 22, 2016 3:01 am
bikerman
bikerman
Post  bikerman on Thu Sep 22, 2016 3:11 am
My favourite parking spot at work
bikerman
bikerman
Post  JRZ7285 on Fri Sep 23, 2016 12:01 am
bikerman wrote:My favourite parking spot at work
Sweet Looking Bike my friend! 2 thumbs
JRZ7285
JRZ7285
Post  bikerman on Fri Sep 23, 2016 12:56 am
Thanks! The only issue I have is the carb, I have some popping when Inlet go the Throttle and I don't know what could be, any ideas where to start?
bikerman
bikerman
Post  Mauser on Fri Sep 23, 2016 7:32 am
I think the popping is normal...just un-burnt fuel being sucked through and then detonating in the system.....my 1300 pops like man on de-acceleration specially after opening her up first.....wakes the neighbours lol
Post  bikerman on Fri Sep 23, 2016 11:02 am
Lol! Well Mauser at least the cars can hear us when we are aproaching them!
bikerman
bikerman
Post  JRZ7285 on Fri Sep 23, 2016 11:39 am
bikerman wrote:Thanks! The only issue I have is the carb, I have some popping when Inlet go the Throttle and I don't know what could be, any ideas where to start?
What elevation do you mostly ride and what is your current jetting?
i run from sea level too about 500' open inlet, hrc tip, 68s pilot, b53e needle middle clip position, 172 main, fuel mixture screw 2.25 turns out from lightly seated and she pulls hard all through the rpm range has very minimal pop on decel
i have read on other sites that your pilot or slow jet as some call it may effect popping on decel and may need ti richen up the mixture via the fuel screw, but it took me a while to finally get mine to where she runs nearly perfect all through the rpm range being a little rich than lean
JRZ7285
JRZ7285
Post  bikerman on Fri Sep 23, 2016 2:01 pm
Toronto sea level is 76 mt and I can't remember but looks like I have the same set up like yours, I will have to double check , she was running nice last year but I went eith a HRC cam with the rebuilt and open up a bit the head port so for sure I will have to re adjust my carb
bikerman
bikerman
Post  bikerman on Fri Sep 23, 2016 5:17 pm
I wanted to make sure she wasn't leaking any oil behind the skid plate so There she is with the new skid plate on
bikerman
bikerman
Post  JRZ7285 on Fri Sep 23, 2016 10:55 pm
bikerman wrote:Toronto sea level is 76 mt and I can't remember but looks like I have the same set up like yours, I will have to double check , she was running nice last year but I went eith a HRC cam with the rebuilt and open up a bit the head port so for sure I will have to re adjust my carb
let us know what you find when open up carb, i need too do a valve clearance check on mine hour meter reads 33.2 hours since last checked! the ole pig still fires up 1st or 2nd kick runs mint not sure if i should bother ? How often do you check your valves?
JRZ7285
JRZ7285
Post  Mauser on Fri Sep 23, 2016 11:23 pm
Checked mine once in 5 years...spot on but I'm not ham fisted like you lot razz
Post  bikerman on Fri Sep 23, 2016 11:28 pm
I haven't bother to check mine in the last 4 years like Mauser! Lol! I wouldn't bother but that's just me! It doesn't take much if you feel safe doing it go ahead and do it.
bikerman
bikerman
Time to switch to Fully Synthetic oil?
Post  bikerman on Sat Sep 24, 2016 2:52 pm
Hey Guys,
I want to change to fully synth oil, I know Burrp was saying some brands like the shell helix but is this car oil or special for motorcycles? also is too early to switch or should I wait a bit more?
bikerman
bikerman
