it dies when i acelerate
Post  babuja on Sun Dec 20, 2015 3:58 pm
Hi guys, need some opinions on this issue.
My XR  didn't work for some time.
Last weekend I wanted to go for a ride and put it out of the garage.
Kicked it once and she worked...but when I accelerated it died.
I removed Carb TM40, opened and cleaned jets. Reinstalled it and kicked it once and, again, she work...but the issue is still there.
Also changed change spark plug for a new one.
Any ideas guys?
babuja
babuja
Re: it dies when i acelerate
Post  Mauser on Sun Dec 20, 2015 4:12 pm
Does she cut out or just bog down ?, my old 250R was terrible if I left the choke on...worth a look ?
Post  babuja on Sun Dec 20, 2015 5:34 pm
Mauser wrote:Does she cut out or just bog down ?, my old 250R was terrible if I left the choke on...worth a look ?
No choke on...when I touch the accelerater it just dies, simple as that
babuja
babuja
Post  Mauser on Sun Dec 20, 2015 6:15 pm
Pull the plug and see what colour it is ?...rich or lean @ time of death BRP smile
Post  babuja on Mon Dec 21, 2015 10:18 am
Mauser wrote:Pull the plug and see what colour it is ?...rich or lean @ time of death BRP smile
Reach with carbon flouded evidence, need to adjust...but first to put it back working.
babuja
babuja
Post  Hew on Mon Dec 21, 2015 4:13 pm
Reach with carbon flouded evidence, need a hoter sparkplug to test results.
Have you checked the air filter as it might be full of dirt. That would choke it.
Hew
Hew
Post  babuja on Mon Dec 21, 2015 4:31 pm
Air filter is off
babuja
babuja
Post  Hew on Mon Dec 21, 2015 10:12 pm
I know a bike of mine with a FCR had similar symptoms when the slide was installed back to front. I don't think it is possible to do the same on the TM though?
Hew
Hew
Post  babuja on Tue Dec 22, 2015 6:36 am
Hew wrote:I know a bike of mine with a FCR had similar symptoms when the slide was installed back to front. I don't think it is possible to do the same on the TM though?
The bike was running great...i just left it stoped for some time
babuja
babuja
Post  Hew on Tue Dec 22, 2015 3:52 pm
I have used Silkolene FST on another bike to prevent carb icing but it also cleans the carb as well and I now add it to fuel when a bike has been standing a while to clean the green gunge that starts to build in the carb. It could be worth a try.
http://www.ebay.co.uk/itm/Silkolene-PRO-FST-Fuel-System-Treatment-For-Petrol-Engines-1-LITRE-1L-/171286371436?hash=item27e1769c6c:g:ni8AAOSwkNZUfbpe
Hew
Hew
Post  babuja on Tue Dec 22, 2015 4:01 pm
Hew wrote:I have used Silkolene FST on another bike to prevent carb icing but it also cleans the carb as well and I now add it to fuel when a bike has been standing a while to clean the green gunge that starts to build in the carb. It could be worth a try.
Thanks mate
babuja
babuja
Post  babuja on Tue Dec 22, 2015 4:07 pm
Some additional infos. Bike starts at first kick, cool or hot. When I open choke it works better. Still, if I touch accelerater it dies. So be issue should be or lack of fuel (jet problem) or too much air. Tested air leak and found none. Have dissambled Carb again and will do another jet cleaning.
babuja
babuja
Post  ewbarger on Fri Sep 16, 2016 5:58 am
Sounds like she's not getting enough fuel. Check your vent tube on the gas tank, then check fuel line, float needle.
ewbarger
ewbarger
