trailtech vapour power
Hi, recently had me a trailtech vapour for 650r, it says i can splice into the wiring to get a constant power suply, but how do i do this?? from where and to where? all wires i have are a direct plug in
Re: trailtech vapour power
Should have 12volts to rear light or coming straight out of the regulator under the seat....that's AC not DC by the way
If it were me I would get some Japanese connectors from fleabay and make a short lead which will connect into existing loom without cutting it ?.....they do a piggy back connector....
http://www.ebay.co.uk/itm/Bullet-Connectors-Terminals-3-9mm-Male-Female-Double-Assortment-Japanese-/170711512131?hash=item27bf32f443:m:mrTTOgH1tXLJr6ndhwDGpRg
What i dont understand is where i wire it to the trailtech unit?
If i connect a wire from my brake light or headlight then where do i connect it upto the unit?
witch wires from the trailtech join my brakelight/headlight?
Sorry I thought you knew what wires did what and were struggling where to connect back to the bike ?, what model do you have ?....have you Googled it ?
this is how I connected mine, I cut the wires before the regulator/rectifier and connected a dual female bullet connector to the regulator/rectifier side and single male bullet connector to the trailtech and main harness side.
I can isolate my battery and the trailtech still gets enough volts at idle to work. Also I believe the trailtech can run on AC or DC so you could power it off the lighting circuit.
hth
hth
Correct, TT's take any supply, up to 400V I think, AC or DC - so just connect the TT's power cable wires (2!) to wherever you find a potential.... and that you do with a mulitmeter!
Simple hmm?
Simple hmm?
appleseed wrote:this is how I connected mine, I cut the wires before the regulator/rectifier and connected a dual female bullet connector to the regulator/rectifier side and single male bullet connector to the trailtech and main harness side.
hth
Hi Appleseed
Where did you site your battery, and what size/model was it.
I bought a 200w stator, just not got round to fitting it yet. My plan is to fit a battery at the same time.
I run a 1300 nimh battery pack under the bracket (part number 5 in the microfiche) that used to hold the original speedo. it doesnt hold enough juice to power things for very long with the engine off but it server its purpose.
I put the battery in a small water proof case (Lomo Drybox 17 Mini Size Transparent - Orange / Clear. Kayak Dry Box). Had to drill a few holes for wires and mounting bolts in it but i have not had any issues (just used some sugru to seal it up)
I also tried a 3700 mah trail tech battery but it was a bit tight squeeze in the dry box, so i went back to the 1300 mah battery as there wasnt any real advantage for me in having the 3700 mah battery (also i was worried it would get damaged in the dry box and catch fire or leak crap.
I dont run the standard headlight shroud but it probably would work with the standard shroud but you may need to stabilise the bracket with some home made brackets.
The trailtech probably would fit under the seat as well but for me that would mean extra wiring going back under the tank etc and may need water proofing.
» Selfmade cockpit for a trailtech vapor
» 12 V Power
» How much power is left?
» vapour trail tech speedo
» SEE TO MUCH POWER
» 12 V Power
» SEE TO MUCH POWER
