Shock measurements needed
Hi,
I am trying to get the parts I need to rebuild my rear shock but the supplier is requesting a couple of measurements:
Hi mark, yeah I can supply you what you need the shaft should be 16mm I will need to know the bush length eg 12 ,14,15 or 16 mm long? I will stock them but won't know the size without measuring it?
Can anyone confirm that the shaft is 16mm and measure the bush length for me?
Thanks,
Mark
Thanks,
Mark
Re: Shock measurements needed
Hi Mark @ great hardship I have just walked downstairs and measured my shock it's just under 16mm...15.94 but that's measuring between the springs with my vernier.....and then I had to walk back upstairs to post on here.....you owe me BIG TIME
you-da-man Mauser....now what about the bush length....not quite so easy I think....
pretty please...
pretty please...
» Ohlins CRF shock on the pig?
» Help rear shock!
» More Shock Than Awe
» rear suspension
» Is a fan needed?
» Help rear shock!
» rear suspension
» Is a fan needed?
