Wiring help needed.
Wiring help needed.
Post  martins315 on Mon Jul 18, 2016 3:19 pm
Hi.
Bought partly running XR650R 2001 U type (street legal with winkers and horn.). It had BD electirc starter installed and was sold seperatly, so it came with wiring mess. I got it running, but cant get Front/back light running and have problems with reg/rec.
First of all bike have rewinded stator, but I can't find what make it is. It has 8 wires coming out:
1. Black/red
2. Brown
3-4. 2 white
5. Green
6. White yellow
7. Green/white
8. Blue/Yellow
I have connected as I could collors as in original wiring, but 2 white is not matching any connections. As I am missing Pink and Yellow, I connected whites instead. Winkers and horn is working, but Rec/Reg is heating up. I guess that with two whites it is too much power for R/R (stock unit). If I remove one white, winkers and horn is not working. My guess that it is 2x100W stator.
So my questions are:
1. Does anyone understud what I wrote?
2. Can anyone help me?
3. How to measure W on two white wires?
4. How I can get power to Rec/Reg without destroying it?
5. Maybe I have to split 1 white and connect it to Yellow and Pink?
6. Do I really have to add battery if I want to run stock lights and winkers?
Thank you in advance.
Martins
martins315
martins315
Re: Wiring help needed.
Post  Mauser on Mon Jul 18, 2016 6:40 pm
Why don't you pull stator cover and find out where the wires actually go...?
Would have thought each pair of winding would have 2 pairs of colours you should also have another pair feeding the pickup coil.
Looking at stock loom mine has white/yellow and Green as 1 pair and Blue/Red and Brown as second coil.
Black/yellow and Green as pickup coil wires.
