Left Case Broken
Page 1 of 3
Page 1 of 3 • 1, 2, 3
Left Case Broken
Today having fun with my XR and chain broke and got me with a broken left case. F-ing sucks. This is only the 6th time I have had it out since I purchased it. What is the best most durable chain recommended for this bike?
I owned a XR600L and the same thing happened with it long ago. That time resulted in some injury but this time it did not.
Re: Left Case Broken
Any experienced suggestions on where to get the best priced parts and any other information would be helpful.
I fitted the 520 D.I.D ZVM-X chain to my bike....http://sprocketcenter.com/did-520-zvmx-super-street-series-x-ring-sealed-chain.html
Why did you run your bike with a chain that was sub standard ?....what was fitted how old etc ?, once your case breaks your buggered; replacement left sides are like hens teeth
Mauser wrote:I fitted the 520 D.I.D ZVM-X chain to my bike....http://sprocketcenter.com/did-520-zvmx-super-street-series-x-ring-sealed-chain.html
I may have ran a substandard chain or a defective one. Chain was new with only about 100 miles on it. It was rated at 520 and 7800 lbs tensile strength. I thru the box away so not sure make. Anyway its done. Need to make a more educated decision. If this one is the best then I will purchase it in the future, once I have this damaged repaired. Had the same thing happen on my XR600. Little upset about chains at this point. The XR 600 was the last bike I owned. Little upset about chains. Need to make sure I purchase a higher quality next time. Apparently that may be my problem. So how do you know if you purchase a high quality chain versus just paying a higher price. How do you really know what you are buying?
D.I.D are probably the best chains in the world, well documented as regards to durability and tensile strength etc, end of the day they all need maintenance so even good chains will break if not looked after. The 1 mentioned is rated well above the bikes power and I have 100% confidence in the product. I would never buy a chain unbranded which states "High Performance" "Super Tough" and all the other stupid phrases they use.....
I hope you can get your case welded up OK otherwise your on the hunt for a busted engine to rob parts from.
It hurts just too look at that! Can you post a pic of your broken chain? curious to see the break in the chain!
D.I.D. chains should be the standard for these Torque monsters and not be substituted, make sure to use a staked link and not the clip style!
Hope you get it sorted out Spoke!
Spokelh,
6 times?????
Then I know what the problem is - and it's NOT the chain, or brand, or sprocket, or oil, or maintenance.... it's YOU!!!
You still use the clip-type link don't you?
There you go, they're not even to be used on your lawnmower.
Use a RIVET-link - for which' job it is best to use a DID Riveting Tool.
Whilts you're busy buying this tool you may as well buy a DID chain, there's no better.
What type of DID chain?
Fork nows, ask your friendly dealer
6 times?????
Yes only road it 6 times when this happened. It was a clip chain. You satisfied. Did not know any better but from being on this forum I do, so I am happy to have great help from you all like you. Just want to do it correctly from this point on. I do not want to have this problem again with the case. A proper case saver would have definitely reduced the problem on my the 650. Only had the stock Case saver. Tore this on up a bit. Did no good obviously.BuRP wrote:Spokelh,
6 times?????
A proper chain will be needed of course. DID is on my list to buy. If there is a stronger one out there then I will get that one. I will have to post a pic of the break in the chain. It did not break at the clip though.
The 1 I posted is the strongest they do in a 520 pitch ...that's why I firred it
Spokelh wrote:Yes only road it 6 times when this happened. It was a clip chain. You satisfied. Did not know any better but from being on this forum I do, so I am happy to have great help from you all like you. Just want to do it correctly from this point on. I do not want to have this problem again with the case. A proper case saver would have definitely reduced the problem on my the 650. Only had the stock Case saver. Tore this on up a bit. Did no good obviously.BuRP wrote:Spokelh,
6 times?????
I think BuRP misuderstood you and thought you broke your chain 6 times
Yes I did, however having to replace cases (both!) can be easily avoided.
First off SpokelH, I hope you can get new cases - which, obviously, will have an effect on your registration also, new number perhaps?
Then the std case saver is, but you know that now, rubbish. Look for a better one at XRsOnly, and know it is dependant on the size of your front sprocket.
Lastly, NEVER use a clip-type link, and reread my first post, 'not even on a lawnmover' better take literally. Yeah, I know there's a gazillion guys using them for years, never had a problem and blablabla, but I repeat "Never use them!".
You see, a rivet-link CANNOT come loose (if properly riveted hence my suggestion to buy the DID-tool (which of course will do any brand of chain)), so you would have saved your cases in this case (spot the pun lol) - worth it you will agree, so not you have learned.
The most important remark here must be 'please repair the bike?' - for it is a cracker, and you've only rode it (so I find out) 6 times..... it is worth it if you dunno it yet, nothing compares.
Goodluck from my side, and once it is fixed please post a piccie?
SpokelH,
just in case you dunno it, that DID tool also breaks the chain - anywhere, you just take a link out.
You will have to count (use the old chain) the links you need for your bike (dep't on the sprockets, and DO put the back wheel most-forward in the swinger first!), and then you 'break' the new chain accordingly.
Oh, yes, when you buy a new chain you ask them to add two (2!) rivet links to it - 1 you'll use and the 2nd a spare, handy to have if ever you need to take the chain off the bike.
If you're new to this practice on your old chain, some experience here will not go amiss.
I just fitted an EK Gold O-Ring chain - I think they are also pretty decent
He's not alone look at this terrible bike....look at the sprocket close up....it's got a CLIP on top of all that a painted engine as well
Where is the picture. Do not see it on my end of the this bike you are talking about.Mauser wrote:He's not alone look at this terrible bike....look at the sprocket close up....it's got a CLIP on top of all that a painted engine as well
BuRP wrote:Yes I did, however having to replace cases (both!) can be easily avoided.
What do you mean Effect on my Registration? Not familiar with that.
Do you all use a 530 chain instead of a 520 . Looks like a 530 Chain can have a higher rating.
Not sure on availability of a new Left Case yet. Just price of about $350.00 New. Is there a process to get a new Left Case?
Seen used Lefts Cases on Ebay for about $315 to $390 so far. Not sure i would pay that much for used one. Only if I had too with no other option.
Spokelh wrote:BuRP wrote:Yes I did, however having to replace cases (both!) can be easily avoided.
Left case has engine number - Depends where you live and their registration regulations
When you get a new case, I would invest in one of these too. It would have saved you a lot of $!
http://www.xrsonly.com/xrs-only-case-saver-honda-xr650r-14-15-tooth-red
Did he have the correct size Vhris?
This one's effectiveness depends wholly on the gap between case-saver & chain - a minimal gap so as to prevent a "run-up" of the chain to the saver=case, the hammer blow will be minimal with this thing mounted.
BuRP wrote:Did he have the correct size Vhris?
My case will have to act as the case saver when I put my 17T on
Mauser wrote:I brought these just in case....
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=331958272525
Good buy and good pun too
OK cases arrived today and right side has some internal damage....I need your wise opinion I don't think this bit does anything other than deflect oil....?
Shame really as apart from this the cases are really good condition.....
Mauser wrote:OK cases arrived today and right side has some internal damage....I need your wise opinion I don't think this bit does anything other than deflect oil....?
That can be built up with TIG welding no problem
» Where to buy a new left engine case.
» Chain adjuster broken off (what to do best?)
» Exhaust header to left radiator clearance
» Sick......bent/cracked left footpeg bracket
» Looking for a left side fork leg
Page 1 of 3
