Talon 13 tooth front sprocket
Talon 13 tooth front sprocket Empty Talon 13 tooth front sprocket
Post  Chris_w_65 on Mon Sep 12, 2016 8:14 pm
Got mine today - My Pig is now an absoloute beast with 13/45 gearing on a motard -
Best I use my superbike for longer trips
Chris_w_65
Chris_w_65
Talon 13 tooth front sprocket Empty Re: Talon 13 tooth front sprocket
Post  BuRP on Tue Sep 13, 2016 10:51 am
No wheelie?
Well, Mauser...
... you must be right then - which means I must be wrong - so: Sorry Mauser!
Hell, I'm the last guy not to apologize if I'm proven wrong.
(Mauser is on record here stating a Pig cannot wheelie without any hoisting/clutch abuse  Bump )
PS: Ehh Chris, you had a 12T sprocket on when I rode it? It did climb, you've seen it, so I miss a bit here...  BRP smile
Post  Chris_w_65 on Tue Sep 13, 2016 10:59 am
BuRP wrote:No wheelie?
Well, Mauser...
Previous owner at sea level was geared 16/40 for 205km top speed
I went 15/40 with a 190 top speed because of altitude (that is how you rode it)
Now it is 13/45 and top speed should be 148 - I will try it for the week and for Saturday's race and then decide what to run - I wouldn't like to ride all the way to your house with this gearing
Chris_w_65
Chris_w_65
Post  BuRP on Tue Sep 13, 2016 11:49 am
Ah, then when videoing the next clip just let it flow bro, the front will point a bit up but promise, the rear-only grip is enough BRP smile
Take the back roads through Irene the next time, or better, map a route with "most speedhumps".... "It saves the front wheel's tyre of course Occifer!" Bump
Post  Chris_w_65 on Tue Sep 13, 2016 11:55 am
BuRP wrote:Ah, then when videoing the next clip just let it flow bro, the front will point a bit up but promise, the rear-only grip is enough BRP smile
This is as good as it gets for now -
Chris_w_65
Chris_w_65
