Rear brake disk hits caliper mount
Hello there
I have just fitted new tyres to my talon exel wheels fitted them back to the bike but the disk is hard up against the caliper mount. I may have the spacers round the wrong way but even then there would be minimal clearance.
Re: Rear brake disk hits caliper mount
If they fitted before then there is no reason why even with new tyres they should not fit now ?....have you gone for a wider tyre ?
LOL Jay,
you did something wrong.......... but now at least we know you're clumsy, thank your honesty for that
Fixit bru, no rocket science!
Yes I am clumsy lol
But still
The clearance between the brake disk bolt is now only 2mm.
Is that right?
Last thing I wanna do is right my bike off
But still
Is that right?
Yes that's right...if you use normal bolts they will hit !!! you need the Honda low profile disc bolts as it comes very close.Jay69 wrote:Yes I am clumsy lol
But still
Is that right?
I don't suppose you have the depth of the head do you?
I do indeed...3.94mm and here is the clearance....not much !!!
» rear brake lever?
» Brake caliper Pistons
» Help: caliper piston / brake pads
» Interesting rear brake idea
» last job........rear brake
