My bike is running super rich. Can anyone help me please?
My bike is running super rich. Can anyone help me please? Empty My bike is running super rich. Can anyone help me please?
Post  Drewb85 on Sat Dec 10, 2016 10:24 pm
My bike is running super rich. It starts right up with no choke and puffs black smoke from the exhaust. I have a 68 pilot(NOT 68s I will be putting that in when I get it) and 165 main in right now. It had a 72 pilot and 180 main in it when I took carb apart the first time. It runs exactly the same with each setup and I cant adjust with the air fuel mixture. Anyone have this issue happen or can send me in the right direction?
Drewb85
Drewb85
My bike is running super rich. Can anyone help me please? Empty Re: My bike is running super rich. Can anyone help me please?
Post  JRZ7285 on Sun Dec 11, 2016 12:54 am
Drewb85 wrote:My bike is running super rich. It starts right up with no choke and puffs black smoke from the exhaust. I have a 68 pilot(NOT 68s I will be putting that in when I get it) and 165 main in right now. It had a 72 pilot and 180 main in it when I took carb apart the first time. It runs exactly the same with each setup and I cant adjust with the air fuel mixture. Anyone have this issue happen or can send me in the right direction?
post a pic of your plug after a proper run and have you checked your valves? check float level and how many hours that you know on bike?
JRZ7285
JRZ7285
Post  Drewb85 on Sun Dec 11, 2016 1:02 am
I can post a picture of the plug tomorrow but I can tell you it is very black, but not wet. I have not checked the valves but the float is in spec. As far as hours I am not sure but it is in great shape with little wear on the cases. I have not checked compression but at 220 pounds I can nearly stand on the kick start and it wont go down. I guess valves are next.
Drewb85
Drewb85
Post  JRZ7285 on Sun Dec 11, 2016 1:10 am
whats your elevation, is air filter over oiled,  is your bike fully uncorked?
JRZ7285
JRZ7285
Post  Drewb85 on Sun Dec 11, 2016 1:17 am
No need to be sorry. I appreciate the help. Im at about 400' elevation in eastern PA. It is uncooked with an Akrapovic exhaust. as far as the air filter I took it off (twin air) and ran exactly the same. My thing is no matter what I do I can't adjust anything. I guess its internal but i want to be sure before i tear it apart.
Drewb85
Drewb85
Post  Drewb85 on Sun Dec 11, 2016 1:22 am
I can tell you i got the bike non running with no spark. It ended up being the pick up coil so i got a Ricks high output stator.
Drewb85
Drewb85
Post  JRZ7285 on Sun Dec 11, 2016 2:12 am
Drewb85 wrote:I can tell you i got the bike non running with no spark. It ended up being the pick up coil so i got a Ricks high output stator.
yeah your pretty close to my elevation my bike is fully uncorked 68s pilot main is 172 airbox 2 restrictors taken out carb intake boot and HRC exhaust tip, and pilot screw 2 turns out from lightly seated! post a pic of your plug i am sure others on here will help pinpoint your problem as well!
JRZ7285
JRZ7285
