Talon 13 tooth front sprocket
Got mine today - My Pig is now an absoloute beast with 13/45 gearing on a motard -
Best I use my superbike for longer trips
Re: Talon 13 tooth front sprocket
No wheelie?
Well, Mauser...
... you must be right then - which means I must be wrong - so: Sorry Mauser!
Hell, I'm the last guy not to apologize if I'm proven wrong.
(Mauser is on record here stating a Pig cannot wheelie without any hoisting/clutch abuse )
PS: Ehh Chris, you had a 12T sprocket on when I rode it? It did climb, you've seen it, so I miss a bit here...
Well, Mauser...
BuRP wrote:No wheelie?
Well, Mauser...
Previous owner at sea level was geared 16/40 for 205km top speed
I went 15/40 with a 190 top speed because of altitude (that is how you rode it)
Now it is 13/45 and top speed should be 148 - I will try it for the week and for Saturday's race and then decide what to run - I wouldn't like to ride all the way to your house with this gearing
Ah, then when videoing the next clip just let it flow bro, the front will point a bit up but promise, the rear-only grip is enough
Take the back roads through Irene the next time, or better, map a route with "most speedhumps".... "It saves the front wheel's tyre of course Occifer!"
BuRP wrote:Ah, then when videoing the next clip just let it flow bro, the front will point a bit up but promise, the rear-only grip is enough
This is as good as it gets for now -
» 13 Tooth front sprocket
» Talon front sprocket
» 17 front sprocket on a pig
» Sprocket Calculator
» Renthal 13 tooth required
