Float height question
Post  Dallard2 on Tue Sep 26, 2017 9:11 pm
Hey, do you guys set the float as per manual at 16mm? I have read that people move it 2mm. Would that make it right at 18mm or 14mm?
Dallard2
Dallard2
Re: Float height question
Post  Mauser on Tue Sep 26, 2017 11:22 pm
I just leave mine as per book ?, don' have any problems listen up
Post  beaver350 on Wed Sep 27, 2017 10:29 am
Yeah book height works
beaver350
Post  BuRP on Wed Sep 27, 2017 11:15 am
1 or 2mm MORE works to prevent pissing when leant over on the sidestand.
MORE, not less razz
It's a good idea to do even when yours behaves fine still, I did it on mine when I was using the std carb.
Post  Dallard2 on Wed Sep 27, 2017 1:07 pm
Will going 2mm more affect jetting?
Dallard2
Dallard2
Post  Mauser on Wed Sep 27, 2017 5:05 pm
No the float just maintains the fuel level within the bowl, just a reserve quanity to allow for all throttle positions...obviously full throttle will grab a load Smile.
Post  BuRP on Thu Sep 28, 2017 10:07 am
Dallard2 wrote:Will going 2mm more affect jetting?
Yes, if you're anal and measure in nano-furlongs per fortnight..... but No if you're a normal oke who rides bikes Bump
I bet that distinguishing between the two settings with an exhaust-gas analyzer will be fruitless, so do a Nike: Just Do It BRP smile
